3 Replies Latest reply on Oct 28, 2016 1:15 AM by Obi-wan Kenobi
    Code to be evaluated! [003]
    Obi-wan Kenobi Adobe Community Professional
      Hi Scripters!
      is it possible to concentrate more … and of course make it work!?
      var myTables = app.activeDocument.stories.everyItem().tables.everyItem().getElements();
      for ( var t = 0; t < myTables.length; t++ ) {
              if ( myTables[t].appliedTableStyle.name == "xxx" && myWidths = [30, 10, 25, 30] )
                  for (var c = 0; c < myWidths.length; c++) myTables[t].columns[c].width = myWidths[c];
              if ( myTables[t].appliedTableStyle.name == "yyy" && myWidths = [10, 20] )
              if ( myTables[t].appliedTableStyle.name == "zzz" && myWidths = [10, 50, 30] )
        • 1. Re: Code to be evaluated! [003]
          Peter Kahrel Adobe Community Professional & MVP
          This is more concentrated:
            switch (myTables[t].appliedTableStyle.name) {
              case 'xxx': myWidths = [30, 10, 25, 30]; break;
              case 'yyy': myWidths = [10, 20]; break;
              case 'zzz': myWidths = [10, 50, 30];
          But whether it works I've no idea.
          Peter
          • 2. Re: Code to be evaluated! [003]
            Hi Peter,
            With, as beginning:
            Nice code!  It works fine!
            I'm going to study it!
            Thanks!
            • 3. Re: Code to be evaluated! [003]
              Even if  the user needs to enter his own table styles and columns numbers/widths per style in the script, its code is really easy to read and understand!
              Just follow the rabbit!
                      Just replace 'xxx', 'yyy', 'zzz', … by your own table styles.
                      Insert the column widths per table style you want to be applied: here, [30, 10, 25, 30], about a 4-columns table!
                      Eventually, add or delete lines.
                  default: alert ("No Table Style found! …\r(^/)  :("); exit ()
              alert ("Done!\r(^/)  ;-)")
              When work is done! …
              If no table styles found! …
