2 Replies Latest reply on Oct 28, 2016 1:10 PM by amaarora
    Unable to change the footer
    Matt-HGO
      Hello Guys,
      eventhough I'm using InDesing for quite some time, I never really worked myself into the deep magic of it becase I only had to use it for our schools yearbook.
      But now to my problem: I have a footer with the date of last year which must be removed but I cant find how to do it. It disappears when I hide the main layer it is in but doesnt disapear when I'm hiding any of its sub layers. Every try to remove it whit any tool failed. Does anyone know what i could do? (There also is no box around it.)
      Specs:
      OS: Win 7 Pro 4-Bit
      InDesing v.: 2015.4
      Propably its an obvoius solution but because I dont know what to search for i just cant find a solution.
      Thank you in advance
                                         Matthias
        • 1. Re: Unable to change the footer
          BarbBinder Adobe Community Professional
          The footer should be on the master page—it that where you are trying to delete it? Use the Pages panel to navigate to the A-Master (or whatever the primary master is called) and change it there.
          • 2. Re: Unable to change the footer
            amaarora Adobe Employee
            As BardBinder said the footer can be edited from the master page. You can also see if the footer is not locked, this can be seen from the layers panel.
            also tip: always insert dates/years as indesign variables so that they are updated automatically and you dont spend time changing them.
            hope this helps
