1 Reply Latest reply on Oct 31, 2016 1:56 AM by natrev
    Check if artLayer has color in it ?
    Dariusz1989 Level 1
      Hey
      I load in photoshop 20 layers. As I load them I'd like to check if a layer has any RGB value or its just pure black, I guess it could be done via levels but not sure.
      In any case how can I check if active layer has a color value in it? Then if there is just black I can just delete the layer.
      I guess I would also like to check if newly created channel with color in it also has data in it.. I know if its black and when I try to CTRL+Click to select I will get a warning that channel is empty and nothing can be selected... I guess is how can I capture that check and get a true/false result out of it.
      Regards
      Dariusz
      Message was edited by: Dariusz Makowski
        • 1. Re: Check if artLayer has color in it ?
          natrev Level 3
          Hi Dariusz,
          Try this Code..
          Special thanks to c.pfaffenbichler
          -yajiv
          #target "photoshop"
          $.level=2;
          function GetLayerValue(CHN){
              var myDocument = app.activeDocument;
              var theHistograms = new Array;
              var theResults = new Array;
              for (var m = 0; m < CHN; m++) {
                  var thisHisto = myDocument.channels[m].histogram;
                  var theCheck = false;
                  var theNumber = 0;
                  // check for the first non-zero value;
                  while (theCheck == false) {
                      if (thisHisto[theNumber] > 0) {
                      theCheck = true;
                      var thisNumber = (255 - theNumber) * 100 / 255;
                      theResults.push (Math.round(thisNumber));
                  theNumber++
                  theHistograms.push(myDocument.channels[m].histogram);
              return theResults;
          var docRef = app.activeDocument;
          var layerRef = docRef.artLayers;
          var theNumber = docRef.layers.length-1;
            for (var m = theNumber; m >= 0;m--){
                LayerVisible(docRef);
                var theLayer = docRef.layers[m];
                if (theLayer.typename == "ArtLayer"){
                  theLayer.visible=true;
                  if (app.activeDocument.mode == DocumentMode.CMYK) {
                      var Colvalue= GetLayerValue(4)
                      theLayer.visible=false;
                      alert("Alert!\nLayer Name : "+theLayer.name +"\nColor value  : "+Colvalue);
                      if(Colvalue[0]==0 && Colvalue[1]==0 && Colvalue[2]==0 && Colvalue[3]>0){
                          alert(theLayer.name +" layer have pure black value");
                  if (app.activeDocument.mode == DocumentMode.RGB) {
                      var Colvalue= GetLayerValue(3);
                      if(Colvalue[0]==0 && Colvalue[1]==0 && Colvalue[2]==0){
          function LayerVisible(docRef){
              var l=docRef.layers.length
              while(l--){
                  docRef.artLayers[l].visible=false;
