4 Replies Latest reply on Oct 30, 2016 12:05 PM by rob day
    Must we change the language paragraph by paragraph?
    AndreBellaiche
      The choice of the language in the Control panel does not seem to be reproduced in the Paragraph Style panel. Does this mean that if I want to change the language from English (U.K.) to French in a document, to get correct French hyphenation, I have to change the language by hand in every paragraph?
        • 1. Re: Must we change the language paragraph by paragraph?
          If you want all text to be in French the best way would be to change it in the Paragraph Style definitions, but you can use Find/Change to override one language (look for it in the Find Format settings) and change to another (in the Change Format).
          • 2. Re: Must we change the language paragraph by paragraph?
            Sandee Cohen Adobe Community Professional
            The Language setting is under Advanced Character Formats in the Paragraph Style panel.
            Change it in the para style.
            Or, if you need only certain words, make a charact-style attribute under the same sub-head.
            • 3. Re: Must we change the language paragraph by paragraph?
              AndreBellaiche Level 1
              Advanced Character Formats (that is "Formats de caractère avancés"). Very funny location. Thank you P eter and Sandee.
              • 4. Re: Must we change the language paragraph by paragraph?
                Very funny location
                Language is a character level attribute so it can be assigned in a number of places—Character, Character Style, Paragraph Style, and Control panels all have language settings. If you have a long document with a mix it can be difficult to get it into a single language.
                If you are using OSX this AppleScript will set everything (Paragraph Styles, Character Styles, and paragraphs) to French in an existing document with mixed languages:
                set lang to "French"
                tell application "Adobe InDesign CC 2014"
                    set pstyles to all paragraph styles of active document
                    repeat with i from 1 to number of items in pstyles
                        try
                            set applied language of item i of pstyles to lang
                        end try
                    end repeat
                    set cstyles to all character styles of active document
                    repeat with i from 1 to number of items in cstyles
                        try
                            set applied language of item i of cstyles to lang
                        end try
                    end repeat
                    try
                        set applied language of every paragraph of every story of active document to lang
                    end try
                    try
                        set applied language of every paragraph of every cell of every table of every story of active document to lang
                    end try
                end tell
