1. Re: 2016 Installation on El Capitan
nic_tunney Oct 30, 2016 6:14 PM (in response to chadv30503923)What errors do you get in the terminal when starting? I'd think that it would start correctly, regardless of the Apache locations you selected when setting up the web server connector. You can also try to hit localhost:8500/CFIDE/administrator, but those console errors are going to be key to figuring it out. Since it was a fresh install, uninstalling reinstalling might also be a good idea.
2. Re: 2016 Installation on El Capitan
chadv30503923 Oct 31, 2016 8:57 AM (in response to nic_tunney)I uninstalled and deleted the Coldfusion2016 directory then reinstalled. The error happens when I attempt to start CF for the first time.
I attempted to run the script ./coldfusion start and it gives me the following results.
Running the ColdFusion 2016 connector wizard
Configuring the web server connector (Launched on the first run of the ColdFusion server start script)
Running /private/etc/apache2 connector wizard...
There was an error while running the connector wizard
Connector installation was not successful
If the connector has already been configured, rename the script cfusion/bin/cf-connectors.sh to prevent the connector from configuring again.
Configuring ColdFusion 2016 to start on system init.
Creating the ColdFusion 2016 start script /Library/StartupItems/ColdFusion2016/ColdFusion2016
mkdir: /Library/StartupItems/ColdFusion2016: File exists
Install complete
Start ColdFusion as "./coldfusion start" to run ColdFusion as non-root user.
Any help you can provide would be greatly appreciated!
Thanks in advance.
3. Re: 2016 Installation on El Capitan
chadv30503923 Oct 31, 2016 11:54 AM (in response to chadv30503923)update... I wanted to post a quick update incase anyone else is having this issue.
This is what I have done so far....
I wiped out the entire install of El Capitan and replaced fresh. I installed CF 2016 prior to installing OS X server. This time the install worked the first time and I was able to access the admin panel and login.
I then installed the OS X Server and CF is still working. Apache may be running a little strange but not sure yet. It seems to be stuck in some weird redirect loop.
I will install MySQL and see if I am able to make anything work.
I will post any updates.
