14 Replies Latest reply on Nov 2, 2016 8:59 AM by BJ40films
    Premiere Elements 15 - m2t import doesn't work.
    BJ40films
      Hello,
      I've got a problem. If I use HDVSplit to capture some footage from a HDV camcorder in the m2t format, and import that in Premiere Elements 15, it gives an error message. 'This file is not supported or the codec is missing' (something like that), however if I have a look here: Supported file formats it's definitely in the list.
      I think there's something with the codec, but I've got no idea how to solve it. I may have to have a look into the ffdshow settings...
      If you've got an idea how to solve it, please let me know. Thanks!
        • 1. Re: Premiere Elements 15 - m2t import doesn't work.
          How are you adding this video to your project? HDV/M2T will definitely edit in Premiere Elements 15.
          Note, however, that, per the program's Help files, some video requires you to install Quicktime's components in order to be fully editable in Premiere Elements. To do this, download Quicktime 7 and, using the Custom installation, opt to install everything EXCEPT Quicktime player.
          QuickTime 7.6 for Windows
          Once you've done that, using Add Media/From Files and Folders and then using the M2T as the first video clip on Video 1 on your timeline should activate all of the necessary components.
          • 2. Re: Premiere Elements 15 - m2t import doesn't work.
            BJ40films Level 1
            Thanks Steve! I'm just adding video files via, 'add media' and I then select 'from files and folders'. I'm installing the newest version of quicktime right now, I still had a very old version on my pc..
            Let's see if that helped...
            Add media, files and folders... Let's see.. No, it still gives that same message as before. 'This file is not supported or the codec is missing'.
            What weird is though, if I open Windows file explorer and try to delete the video file I tried to import into Premiere Elements, it gives a popup: 'cannot delete file because it is opened in Premiere Elements', however, in Premiere the video file doesn't show up in 'project elements'.
            • 3. Re: Premiere Elements 15 - m2t import doesn't work.
              Something is definitely up, BJ. But I can't tell what it is.
              I'd try starting up a new project and trying again.
              If that doesn't work, download the free Media Info program. Open your M2T file in it and then post the report it generates so we can see what's inside that file.
              • 4. Re: Premiere Elements 15 - m2t import doesn't work.
                BJ40films Level 1
                I'll try that. New project, import.. No, it still gives the same message..
                But maybe it's due to HDVSplit, what if I try another program?
                If I import a file in MediaInfo, it says this:
                General
                Complete name                            : C:\Users\Gijs\Videos\Eekhoorn\Eekhoorn-2016_10_30-16_50.m2t
                Format                                   : MPEG-TS
                Commercial name                          : HDV 1080i
                File size                                : 107 MiB
                Duration                                 : 32 s 940 ms
                Start time                               : UTC 2016-10-30 16:50:58
                End time                                 : UTC 2016-10-30 16:51:31
                Overall bit rate mode                    : Variable
                Overall bit rate                         : 27.0 Mb/s
                Maximum Overall bit rate                 : 33.0 Mb/s
                Encoded date                             : UTC 2016-10-30 16:50:58
                Video
                Menu ID                                  : 100 (0x64)
                Format                                   : MPEG Video
                Format version                           : Version 2
                Format profile                           : Main@High 1440
                Format settings, BVOP                    : Yes
                Format settings, Matrix                  : Custom
                Format settings, GOP                     : M=3, N=12
                Format settings, picture structure       : Frame
                Codec ID                                 : 2
                Duration                                 : 32 s 560 ms
                Bit rate mode                            : Constant
                Bit rate                                 : 25.3 Mb/s
                Maximum bit rate                         : 25.0 Mb/s
                Width                                    : 1 440 pixels
                Height                                   : 1 080 pixels
                Display aspect ratio                     : 16:9
                Frame rate                               : 25.000 FPS
                Standard                                 : Component
                Color space                              : YUV
                Chroma subsampling                       : 4:2:0
                Bit depth                                : 8 bits
                Scan type                                : Interlaced
                Scan order                               : Top Field First
                Compression mode                         : Lossy
                Bits/(Pixel*Frame)                       : 0.650
                Stream size                              : 98.1 MiB (92%)
                Color primaries                          : BT.709
                Transfer characteristics                 : BT.709
                Matrix coefficients                      : BT.709
                Audio
                Format                                   : MPEG Audio
                Format version                           : Version 1
                Format profile                           : Layer 2
                Codec ID                                 : 3
                Duration                                 : 33 s 0 ms
                Bit rate                                 : 384 kb/s
                Channel(s)                               : 2 channels
                Sampling rate                            : 48.0 kHz
                Delay relative to video                  : 120 ms
                Stream size                              : 1.51 MiB (1%)
                Menu
                List                                     : 2064 (0x810) (MPEG Video) / 2068 (0x814) (MPEG Audio) / 2069 (0x815) () / 2065 (0x811) ()
                • 5. Re: Premiere Elements 15 - m2t import doesn't work.
                  This appears to be a pretty standard 1440x1080 MPEG. There's no reason the program should reject it.
                  However, if you'd like, you can put a sample of this video in Dropbox and share it with me (My first name at my web site Muvipix dot com -- never put your e-mail address on a forum page) and I'll be glad to try it in my program.
                  Make sure you reference this discussion in your "share notification" e-mail so I'll be able to track it back. (I help dozens of people every day.)
                  • 6. Re: Premiere Elements 15 - m2t import doesn't work.
                    BJ40films Level 1
                    Thanks for your reply Steve. It's a strange problem, that's for sure.
                    OK, so I've put a video file in Onedrive, as I don't have dropbox, I think it works almost the same as dropbox. Ehhhe, "myfirst name at my web site muvipix.com", what do you mean with that?
                    I've been searching around for a while now, and tried the jive help, but I can't find my 'share notification' email, where can I find that? Dozens of people, that's a lot...
                    • 7. Re: Premiere Elements 15 - m2t import doesn't work.
                      You need to share the file with me, BJ, or I can't experiment with it.
                      OneDrive is online backup. You need to put the file on Dropbox and select the Share option in order to share it with me.
                      • 8. Re: Premiere Elements 15 - m2t import doesn't work.
                        BJ40films Level 1
                        Thought OneDrive could do that too... But anyway, I made a dropbox account, uploaded the file and pressed share. Now I need to type in an email adress: 'my first name at my web site muvipix.com'.
                        "Make sure you reference this discussion in your "share notification" e-mail so I'll be able to track it back." Now I got it, I need to reference to this discussion in that share mail thingie.
                        If everything went well, you should have an email in your mailbox right now..
                        • 9. Re: Premiere Elements 15 - m2t import doesn't work.
                          I've received no e-mails from Dropbox, BJ. You did send it to Steve@ my web site, right?
                          • 10. Re: Premiere Elements 15 - m2t import doesn't work.
                            BJ40films Level 1
                            Yes I typed Steve at your website dot com. Dropbox even says that Steve Grisetti can see it. Should I post a link to the file here?
                            • 13. Re: Premiere Elements 15 - m2t import doesn't work.
                              Thanks for sharing the file, BJ.
                              I downloaded it and it dropped right into my program with no problems. (I used Add Media/from Files and Folders.) In fact the program matched the specs perfectly when I added it to Video 1.
                              So there's nothing at all wrong with the file or the program's handling of it. I still don't know what's going on at your end though. Sorry.
                              • 14. Re: Premiere Elements 15 - m2t import doesn't work.
                                BJ40films Level 1
                                Thanks Steve! Weird... Let's see what happens if I download it of dropbox, don't think that makes a difference though, but you never know..
                                No, that doesn't change a thing.
                                I'm going to re-install Premiere Elements let's see if that'll help...
                                Yes that helped a lot. A re-install did the trick, now it's working fine again!
