0 Replies Latest reply on Oct 31, 2016 5:27 PM by kuix35033267
    pid not readable (yet?) after start
    kuix35033267
      I have installed aem6.2 on Ubuntu 16.04.1 which runs on an Amzon EC2 instance.
      Now I wish aem should restart automatically on system reboot.
      So added below script to /etc/init.d/aem62
      #!/bin/bash
      ### BEGIN INIT INFO
      # Provides:          aem62
      # Required-Start:    $local_fs
      # Required-Stop:     $local_fs
      # Default-Start:     2 3 4 5
      # Default-Stop:      0 1 6
      # Short-Description: aem62
      ### END INIT INFO
      # Source function library.
      #. /etc/rc.d/init.d/functions
      SCRIPT_NAME=`basename $0`
      AEM6_ROOT=/opt/aem62/publish
      AEM6_USER=root
      SERVER="${AEM6_ROOT}/crx-quickstart"
      START="${SERVER}/bin/start"
      STOP="${SERVER}/bin/stop"
      STATUS="${SERVER}/bin/status"
      case "$1" in
      start)
      echo -n "Starting aem62 services... "
      echo
      su - ${AEM6_USER} ${START}
      touch /var/lock/subsys/aem62
      stop)
      echo -n "Shutting down aem62 services... "
      su - ${AEM6_USER} ${STOP}
      rm -f /var/lock/subsys/aem62
      status)
      su - ${AEM6_USER} ${STATUS}
      restart)
      echo "Usage: aem62 {start|stop|status|restart}"
      exit 1
      esac
      and issue the following commands:
      chmod 755 aem62
      update-rc.d aem62 defaults
      but when i check the status of aem service after Ubuntu reboot, get the bellowing log.
      root@ip-10-0-3-10:/etc# service aem62 status
      ● aem62.service - LSB: aem62
         Loaded: loaded (/etc/init.d/aem62; bad; vendor preset: enabled)
         Active: failed (Result: resources) since Mon 2016-10-31 05:56:46 UTC; 20min ago
           Docs: man:systemd-sysv-generator(8)
      Oct 31 05:56:44 ip-10-0-3-10 systemd[1]: Starting LSB: aem62...
      Oct 31 05:56:44 ip-10-0-3-10 aem62[745]: Starting aem62 services...
      Oct 31 05:56:44 ip-10-0-3-10 su[750]: Successful su for root by root
      Oct 31 05:56:44 ip-10-0-3-10 su[750]: + ??? root:root
      Oct 31 05:56:44 ip-10-0-3-10 su[750]: pam_unix(su:session): session opened for user root by (uid=0)
      Oct 31 05:56:46 ip-10-0-3-10 aem62[745]: mesg: ttyname failed: Inappropriate ioctl for device
      Oct 31 05:56:46 ip-10-0-3-10 systemd[1]: aem62.service: PID file /crx-quickstart/conf/cq.pid not readable (yet?) after start: No such file or directory
      Oct 31 05:56:46 ip-10-0-3-10 systemd[1]: Failed to start LSB: aem62.
      Oct 31 05:56:46 ip-10-0-3-10 systemd[1]: aem62.service: Unit entered failed state.
      Oct 31 05:56:46 ip-10-0-3-10 systemd[1]: aem62.service: Failed with result 'resources'.
      I don't know why service access cq.pid file in /crx-quickstart/conf directory.
      Could you tell me how configure it to start automatically,even if no one is logged into the PC?
      Thanks.
