1 Reply Latest reply on Oct 31, 2016 12:49 PM by try67
    PDF Automation
    jaredd69582483
      I am trying to automate multiple steps:
      Step 1: Extract Pages from a Dynamically Generated PDF
      Step 2: Open pages one at a time
      Step 3: Search for and copy first two words on the page (LAST NAME, FIRST NAME)
      Step 4: Rename file with "Date"_"LAST NAME, FIRST NAME"
      I looked into other options and saw that Adobe Bridge has a batch renaming feature.
      But it can only pull from metadata, so if I could automate the "LAST NAME, FIRST NAME" being copied into the Keywords Metadata that option would work.
      Any help on this would be appreciated
        • 1. Re: PDF Automation
          If the pages are consistent then it can be done using Acrobat JavaScript, but it would require the development of a custom-made script that will iterate over the words in each page, looking for the relevant text and then extract the pages using the pattern you specified. It's not a simple task for a novice in Acrobat JS.
