3 Replies Latest reply on Nov 1, 2016 8:27 AM by TᴀW
    load excel spreadsheet to table variable?
    akiva_atwood
      I know how to create a doc, place an excel spreadsheet in the doc, and then refer to the cells of the table....
      Is it possible to skip the "create" and "place" steps -- and do something like
      myTable = new Table;
      myTable = open("path to excel file");
      myData=myTable.rows[2].cells[11].texts[0].contents;
        • 1. Re: load excel spreadsheet to table variable?
          Daniel Sterchi Level 3
          Hi akiva_atwood
          Short answer: no…
          First you need to have a open document. Then you can place a spreadsheet which creates a table inside a text frame. Then you can get the data of a specific field.
          A bit of code:
          main();
          exit();
          function main() {
            // take the open document
            // take the first textframe in my example
            var myTextFrame = myDoc.textFrames[0];
            // take the first table of the first textframe. A table lives inside a textframe
            var myTable = myTextFrame.tables[0];
            // get the data from the cell (1,3)
            var myData = myTable.columns[1].cells[2].contents;
            // write the data to the console
            $.writeln(myData);
          I hope this helps to answer your question
          kind regards
          Daniel
          (from Switzerland)
          • 2. Re: load excel spreadsheet to table variable?
            akiva_atwood Level 1
            Hi Daniel
            I know how to do it that way -- I was hoping to avoid the create and place steps.
            Akiva
            • 3. Re: load excel spreadsheet to table variable?
              TᴀW Adobe Community Professional & MVP
              On Windows, it would be like this:
                var vb;
                vb = "\rSet myExcel = CreateObject(\"Excel.Application\")";
                vb += "\rDim s";
                vb += "\rSet objWorkbook = myExcel.Workbooks.Open(/*Path to Excel Doc*/)";
                vb += "\rSet objSheet = myExcel.ActiveWorkbook.WorkSheets(1)";
                vb += "\rs = objSheet.Cells(1, 2).Text";
                vb += "\robjWorkBook.close";
                vb += "\rreturnValue = s";
                result = app.doScript (vb, ScriptLanguage.VISUAL_BASIC);
              This gives you the plain text of cell 1,2.
              Ariel
