1 Reply Latest reply on Nov 1, 2016 12:24 PM by funkelodeon
    New custom panel doesn't appear in list of extensions
    funkelodeon Level 1
      Hi All,
      So, I'm setting up to build a custom panel for Premiere, and having some issues getting a basic "hello world" example to appear in the list of extensions under Window->Extensions.  I have PProPanel and Anywhere Example Panel working from the Adobe-CEP samples, just not my new panel.
      Folder Structure is:
      extensions/
          HelloWorld/
              CSXS/
                  manifest.xml
              index.html
      My index.html file is very simple:
      <!doctype html>
      <html>
          <body>
              <button id="btn">Click me</button>
          </body>
      </html>
      And manifest.xml is also simple:
      <?xml version="1.0" encoding="UTF-8"?>
      <ExtensionManifest ExtensionBundleId="com.example.helloworld" ExtensionBundleName="Hello World" ExtensionBundleVersion="1.0" Version="4.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
          <ExtensionList>
              <Extension Id="com.example.helloworld.extension" Version="1.0"/>
          </ExtensionList>
          <ExecutionEnvironment>
              <HostList>
                  <Host Name="PPRO" Version="[8.0,20.0]" />
              </HostList>
              <LocaleList>
                  <Locale Code="All" />
              </LocaleList>
              <RequiredRuntimeList>
                  <RequiredRuntime Name="CSXS" Version="5.0" />
              </RequiredRuntimeList>
          </ExecutionEnvironment>
          <DispatchInfoList>
              <Extension Id="com.example.helloworld">
                  <DispatchInfo>
                      <Resources>
                          <MainPath>./index.html</MainPath>
                      </Resources>
                      <UI>
                          <Type>Panel</Type>
                          <Menu>Hello world</Menu>
                          <Geometry>
                              <Size>
                                  <Height>400</Height>
                                  <Width>400</Width>
                              </Size>
                          </Geometry>
                      </UI>
                  </DispatchInfo>
              </Extension>
          </DispatchInfoList>
      </ExtensionManifest>
      I'd expect to see "Hello world" appear in Window->Extensions, but instead I just see two example panels I cited above.
      I'm using Premiere Pro CC 2015.4 on mac. Thanks in advance for your input!
