12 Replies Latest reply on Nov 2, 2016 2:06 PM by George_Johnson
    Acrobat document resizing
    JKuruvilla
      Hello,
      I want to use an applescript to resize my acrobat document (JavaScript also will do). Note that, this is not crop. My current document size is 7.5 inch x 10 inch and I want to make it 8.5 inch x 11 inch. This function available in crop tool (Set Page Boxes/Change Page size/Custom) if I want to do manually. Any help please?
        • 1. Re: Acrobat document resizing
          George_Johnson MVP & Adobe Community Professional
          With JavaScript you'd use the setPagesBoxes method to first set the media box to the size you want and then set the crop box to match.
          • 2. Re: Acrobat document resizing
            JKuruvilla Level 1
            Can you please give me little more insight on this?
            • 3. Re: Acrobat document resizing
              Exactly how do you want to go from 7.5 x 10 to 8.5 x 11? It might be by adding an inch to the right side, or 1/2 inch to both the left and right sides. Same thing for the top and bottom.
              Also, do you want to do this for every page in the document, or just certain ones?
              • 4. Re: Acrobat document resizing
                JKuruvilla Level 1
                Thanks George for your feed back. I know how to do this manually, I have a bunch of PDFs with single pages. I am trying to find out an automated system such as applescript or JavaScript for the ongoing solution.
                • 5. Re: Acrobat document resizing
                  Yes, I'm willing to show you how, but it would be helpful if you provided the information I asked about. The details are important.
                  • 6. Re: Acrobat document resizing
                    JKuruvilla Level 1
                    Yes. It is single page document. I want to add 1/2 inch each on all four sides. meaning currently, it is 7.5x10 inches and want to get it as 8.5x11. thanks again.
                    • 7. Re: Acrobat document resizing
                      Here's a basic script that should help you get started. It adds 1/2 inch to all sides of the page and assumes the page isn't rotated.
                      // Get the rect (left, top, right, bottom) for the media box of the current page
                      var aRect = getPageBox({cBox: "Media", nPage: 0});
                      // Set the  increment value, in points (72 points/inch)
                      var inc = 0.5 * 72;
                      // Set a new media box
                      setPageBoxes({cBox: "Media", nStart: 0, nEnd: numPages - 1, rBox: [aRect[0] - inc, aRect[1] + inc, aRect[2] + inc, aRect[3] - inc]});
                      You can run this script in the interactive JavaScript console (command + J), in a custom action, custom toolbar or menu item, etc. Post again if you need more help and consulting the Acrobat JavaScript reference is always a good idea.
                      • 8. Re: Acrobat document resizing
                        Dima_Tysha
                          pageCnt = this.numPages;
                          // calc target dim in pt
                          var targetPageWidth = nSiX * 72 / 25.4;
                          var targetPageHeight = nSiY * 72 / 25.4;
                          t.duration = pageCnt;
                          t.begin();
                          for (var i = 0; i < pageCnt; i++ ){
                          t.value = i;
                          t.text = "Зміна розміру сторінки " + (i + 1);
                          // для MediaBox
                          var oRect = this.getPageBox("Media", i);// get old value of MediaBox
                          // розрахувати різницю
                          var mediaBox_dX = (targetPageWidth - oRect[2] - oRect[0]) / 2;
                          var mediaBox_dY = (targetPageHeight - oRect[1] - oRect[3]) /2;
                          // set new dimentions
                          this.setPageBoxes({
                          cBox: "Media",
                          nStart: i,
                          rBox:[
                          oRect[0] - mediaBox_dX,
                          oRect[1] + mediaBox_dY,
                          oRect[2] + mediaBox_dX,
                          oRect[3] - mediaBox_dY,
                          // для CropBox
                          var oRect = this.getPageBox("Crop", i);// get old value of CropBox
                          var dX = (targetPageWidth - oRect[2] - oRect[0]) / 2;
                          var dY = (targetPageHeight - oRect[1] - oRect[3]) /2;
                          this.setPageBoxes({
                          cBox: "Crop",
                          nStart: i,
                          rBox:[
                          oRect[0] - dX,
                          oRect[1] + dY,
                          oRect[2] + dX,
                          oRect[3] - dY,
                          // для TrimBox
                          var oRect = this.getPageBox("Trim", i);// get old value of TrimBox
                          this.setPageBoxes({
                          cBox: "Trim",
                          nStart: i,
                          rBox:[
                          oRect[0] + mediaBox_dX,
                          oRect[3] + mediaBox_dY,
                          // для BleedBox
                          var oRect = this.getPageBox("Bleed", i);// get old value of BleedBox
                          this.setPageBoxes({
                          cBox: "Bleed",
                          nStart: i,
                          rBox:[
                          // для ArtBox
                          var oRect = this.getPageBox("Art", i);// get old value of ArtBox
                          this.setPageBoxes({
                          cBox: "Art",
                          nStart: i,
                          rBox:[
                          t.end();
                        • 9. Re: Acrobat document resizing
                          JKuruvilla Level 1
                          Thanks George, I think I am very close. I am getting the following error.
                          ReferenceError: aRect is not defined
                          1:Console:Exec
                          undefined
                          • 10. Re: Acrobat document resizing
                            When you execute it in the console, you have to select all of it and press command+return.
                            • 11. Re: Acrobat document resizing
                              JKuruvilla Level 1
                              Thanks George. This works Good. One more question. How can I put this in loop? so that, I can select a bunch of PDFs, run at one time. Probably, an external script? how that will work?
                              • 12. Re: Acrobat document resizing
                                That what custom Actions are for. You can set one up with a single JavaScript action and process the files you select when you trigger the action. You should be able to find more information on creating and using Action in Acrobat with a search.
