5 Replies Latest reply on Nov 10, 2016 11:30 AM by Szalam
    Elements 3d
    Artyomx
      Hello I need a lil help With my ELEMENT 3D v2 ,when I'm adding an object into the scene and trying to add light..the object does not get affected by the light.
      Now the thing is....that if im adding an ambient light (1 of the four light options in AE)
      The object get affected.
      Won't do shadows buy getting affected
      If it's a spot or parallel..the object not getting affected
      I tried everything..just everything.. nothing is seems to work
      Thank you
      And Sorry for my English.
        • 1. Re: Elements 3d
          Without proper system information nobody can tell you much. Most likely this is simply a graphics driver problem.
          Mylenium
          • 2. Re: Elements 3d
            Artyomx Level 1
            hi
            its not about the system preferences because with V1 its worked
            but this is my system
            2.9 Ghz Intel core i7
            8 GB 1600 Mhz ddr3
            IntelHD graphics 4000,1024 MB
            • 3. Re: Elements 3d
              Sorry, but that's nonsense. V2 uses much more advanced features and a different OpenGL implementation and well, you have your answer here:
              That's just not good enough. I believe that's even documented on the Video CoPilot page. You need a dedicated graphics processor.
              Mylenium
              • 4. Re: Elements 3d
                Artyomx Level 1
                and there's nothing i can do?
                like maybe to lower the setting or something?
                any solution will help
                because i can use cineware but its a lot of work and the render time is ridiculous.
                thank you
                • 5. Re: Elements 3d
                  Adding a GPU is the only thing you can do. Element renders exclusively on the GPU and v2 has hardware requirements that the Intel chipset doesn't meet.
