5 Replies Latest reply on Nov 2, 2016 11:46 AM by Captiv8r
    Cannot delete a folder in Project Manager
    MDennetti
      I have renamed a folder in Project Manager in RoboHelp 11. A folder with the new name has been created, but the original folder still exists in Project Manager but not on disk. It contains a sub folder with an "h" icon, which I suspect is why I cannot delete it. The project is one of three child projects in a parent/child environment. Any advice would be appreciated. Thanks
        • 1. Re: Cannot delete a folder in Project Manager
          Perhaps try clearing the CPD?
          Click here to watch a video on how to do that
          Cheers... Rick
          • 2. Re: Cannot delete a folder in Project Manager
            prhmusic2 Level 2
            One thing you can also try is to look at the .fpj file with a text editor like Notepad but
            Be very cautious if you do!!!
            Please use caution if you are poking around in the .fpj file.
            Make a backup of your project to avoid bad things!!!
            That said, don't be scared! <wink>
            You will see something like the following, which is from one of my project folders. Look within the <folder> </folder> tags for the folder that you can't seem to delete.
            <rhpml majorversion="7" minorversion="13">
                <topics>
                    <topic>
                        <name>DocSection_System_Description.htm</name>
                        <comments></comments>
                        <frameset>0</frameset>
                    </topic>
                </topics>
                <folders>
                    <folder>
                        <name>Active Directory</name>
                    </folder>
                    <folder>
                        <name>Xlecera_Cardiac_Monitoring_System</name>
                    </folder>
                    <folder>
                        <name>Citrix</name>
                    </folder>
                    <folder>
                        <name>VOALTE_Clinical_Communication_System</name>
                    </folder>
                    <folder>
                        <name>Data Center Environmental Support Systems</name>
                    </folder>
                    <folder>
                        <name>Diagnostic Imaging Archive PACs_Carestream</name>
                    </folder>
                    <folder>
                        <name>Document Management System_OnBase</name>
                    </folder>
                    <folder>
                        <name>Domain Name Services</name>
                    </folder>
                    <folder>
                        <name>EPIC_Enterprise_Electronic_Medical_Record</name>
                    </folder>
                    <folder>
                        <name>Enterprise Interface Engine_Cloverleaf</name>
                    </folder>
                    <folder>
                        <name>Enterprise Paging System</name>
                    </folder>
                    <folder>
                        <name>Print Servers_Windows and CUPS</name>
                    </folder>
                    <folder>
                        <name>Staff_Duress_System_AEROSCOUT</name>
                    </folder>
                    <folder>
                        <name>Telephone System_NEC</name>
                    </folder>
                    <folder>
                        <name>Wired Data Network</name>
                    </folder>
                    <folder>
                        <name>Wireless Data Network</name>
                    </folder>
                    <folder>
                        <name>Wired_Data_Network</name>
                    </folder>
                    <folder>
                        <name>EPIC</name>
                    </folder>
                </folders>
            </rhpml>
            You may also need to look downstream a level as well. For example, within my "Active Directory" folder, there is also a .fpj file called "Active Directory.fpj"
                <folders>
                    <folder>
                    </folder>
                </folders>
            </rhpml>
            Paul
            • 3. Re: Cannot delete a folder in Project Manager
              Well, yeah there's always that option. You can pull the splinter out using tweezers or you can grab the scalpel and slice open the finger. Your call.
              • 4. Re: Cannot delete a folder in Project Manager
                MDennetti Level 1
                Thanks both of you. I previously tried renaming the .cpd file, with no success. I just removed the reference to the rogue folder in the Root.fpj file and it worked perfectly. Problem solved.
                Cheers,
                Mark
                • 5. Re: Cannot delete a folder in Project Manager
                  LOL, some splinters are stubborn critters.
