4 Replies Latest reply on Nov 3, 2016 8:54 AM by vangroover
    ERROR: phonegap-plugin-push version 1.8.4 throwing error on Android build
    ablopezmty Level 1
      Expected Behaviour
      The Android app should compile in PhoneGap Build normally when using version 1.8.4 of the phonegap-plugin-push plugin on NPM.
      Actual Behaviour
      The app doesn't compile due to a "Could not find any version that matches com.google.android.gms:play-services-gcm:9.8+" error.
      Note that using version 1.8.3 works just fine, but the new 1.8.4 release causes this problem.
      Steps to Reproduce
      Just create an app in PGB using version 1.8.4 of the phonegap-plugin-push plugin and the CLI/platform versions below.
      Cordova CLI version and cordova platform version
      CLI: 6.3.0
      Platform (Android): 5.2.1
      Logs taken while reproducing problem
      Build Date: 2016-11-02 03:22:51 +0000
      Configuration on demand is an incubating feature.
      Incremental java compilation is an incubating feature.
      FAILURE: Build failed with an exception.
      * What went wrong:
      A problem occurred configuring root project 'project'.
      > Could not resolve all dependencies for configuration ':_debugCompile'.
         > Could not find any version that matches com.google.android.gms:play-services-gcm:9.8+.
           Versions that do not match:
               9.4.0
               9.2.1
               9.2.0
               9.0.2
               9.0.1
               + 5 more
           Searched in the following locations:
               https://repo1.maven.org/maven2/com/google/android/gms/play-services-gcm/maven-metadata.xml
               https://jcenter.bintray.com/com/google/android/gms/play-services-gcm/maven-metadata.xml
               file:/android-sdk/extras/android/m2repository/com/google/android/gms/play-services-gcm/ma ven-metadata.xml
               file:/android-sdk/extras/google/m2repository/com/google/android/gms/play-services-gcm/mav en-metadata.xml
           Required by:
               :project:unspecified
      * Try:
      Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
      BUILD FAILED
      Total time: 3.007 secs
      Error: /project/gradlew: Command failed with exit code 1 Error output:
      * What went wrong:
               9.4.0
               9.2.1
               9.2.0
               9.0.2
               9.0.1
               + 5 more
           Required by:
      * Try:
          at ChildProcess.whenDone (/project/cordova/node_modules/cordova-common/src/superspawn.js:169:23)
          at emitTwo (events.js:106:13)
          at ChildProcess.emit (events.js:191:7)
          at maybeClose (internal/child_process.js:877:16)
          at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
