I am encountering this issue when I place certain JPG images in an Indesign file.
As soon as I drop the image on the document, ID crashes then asks to re-open. If I open the image in Photoshop first and save it then try again, it works fine.
Obviously, I (and other work colleagues) cannot do use this workaround constantly as we go through hundreds (if not thousands) of images and its only a percentage that crash ID. It would mean having to identify each image that does this then opening and saving. Adding far too much time to the day!
Below is an excerpt of the crash log [full log is here: pastebin]. [Heres an image that crashes ID]
Process: | Adobe InDesign CC 2015 [50888] |
Path: | /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Adobe InDesign CC 2015 |
Identifier: | com.adobe.InDesign |
Version: | 11.3.0.34 (11300) |
Code Type: | X86-64 (Native) |
Parent Process: | ??? [1] |
Responsible: | Adobe InDesign CC 2015 [50888] |
User ID: | 159799866 |
Date/Time: | 2016-11-02 11:07:23.802 +0000 |
OS Version: | Mac OS X 10.11.6 (15G1108) |
Report Version: | 11 |
Anonymous UUID: | D5F32806-6D1D-6D33-C73F-265C6F25B8CB |
Sleep/Wake UUID: | AC2F9312-8489-4A6F-BE79-8BE18CFD2FF1 |
Time Awake Since Boot: 88000 seconds
Time Since Wake: | 9400 seconds |
System Integrity Protection: enabled
Crashed Thread: | 0 Dispatch queue: com.apple.main-thread |
Exception Type: | EXC_BAD_ACCESS (SIGSEGV) |
Exception Codes: | KERN_INVALID_ADDRESS at 0x0000000000000000 |
Exception Note: | EXC_CORPSE_NOTIFY |
Hi Chris,
We have fixed a similar issue in Id latest update i.e 12.0
In the meanwhile, you can try out the new update and see if your case is fixed or not.
Regards
Abhinav
InDesign Engineering
Hi Chris,
Will you be able to share any of those JPGs which crash InDesign ?
You may share them on abkaushi@adobe.com through Dropbox or Google Drive.
Regards
Abhinav
Abhinav, I have shared one of the images here (also in original post)
It shows, 404 error.
You may have share the file explicitly.
Regards
Abhinav
My apologies for that!
Looks like the http:// was getting added to the end when I was creating the hyperlink
There's something goofy in the metadata. I used bridge to add a keyword and that single change made it placeable. What's the history of these files? Are they all from one source? Did they come out of some sort of asset manager?
They all came from one particular image library
Hi Chris,
Regards
Abhinav
Thank you for this.
I have instigated updating to version 12 company wide. I will mark as resolved.
