• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
javascript .xls import range = a1: "end of table" ?
Community Beginner ,
Nov 02, 2016 Nov 02, 2016
Dear Indesign-script developers!
i'm scripting the import of xls tables that are placed in the indd. within the excelimportpreferences i can define the range of cells to import by "range = a1:b4" (importing row a column1 to row b column4)
simple question: is there a way to get the last row and last column of the xls table? with last i mean the last cell thats not empty.
depending on that information i'd be able to decide if a set range fills my page, or if my range is at the end of the xls table (if the range is beyond the rows/columns end it results in an error and the script simply aborts.)  "try and catch" to import each single row seperately will take too long for real life xls tables, which have up to 10.000 rows...
TOPICS
Scripting
Views
332
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
[moved to InDesign Scripting]
Votes
Translate
Translate
Report
Report
Mentor ,
LATEST
If you would not specify 'range' property - InDesign will import entire 'filled with data' table (to the last not empty col & row)
If your goal is to know this range before import - you will need to open a Worksheet and exam it using Visual Basic snippet.
It can be done running javascript doScript() method since you would build VB code as a String.
See this post for a details:
load excel spreadsheet to table variable?
Jarek
Votes
Translate
Translate
Report
Report
