3 Replies Latest reply on Apr 11, 2018 11:29 PM by bhavikap41876782
    Could not find any version that matches com.google.android.gms:play-services-gcm:9.8+
    jhonnya53729750
      Build Date: 2016-11-02 19:06:15 +0000
      Configuration on demand is an incubating feature.
      Incremental java compilation is an incubating feature.
      Download https://jcenter.bintray.com/com/commit451/PhotoView/1.2.4/PhotoView-1.2.4.pom
      Download https://repo1.maven.org/maven2/com/squareup/picasso/picasso/2.5.2/picasso-2.5.2.pom
      Download https://repo1.maven.org/maven2/com/squareup/picasso/picasso-parent/2.5.2/picasso-parent-2. 5.2.pom
      FAILURE: Build failed with an exception.
      * What went wrong:
      A problem occurred configuring root project 'project'.
      > Could not resolve all dependencies for configuration ':_debugCompile'.
        > Could not find any version that matches com.google.android.gms:play-services-gcm:9.8+.
        Versions that do not match:
        9.4.0
        9.2.1
        9.2.0
        9.0.2
        9.0.1
        + 5 more
        Searched in the following locations:
        https://repo1.maven.org/maven2/com/google/android/gms/play-services-gcm/maven-metadata.xml
        https://jcenter.bintray.com/com/google/android/gms/play-services-gcm/maven-metadata.xml
        file:/project/libs/
        file:/android-sdk/extras/android/m2repository/com/google/android/gms/play-services-gcm/ma ven-metadata.xml
        file:/android-sdk/extras/google/m2repository/com/google/android/gms/play-services-gcm/mav en-metadata.xml
        Required by:
        :project:unspecified
      * Try:
      Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
      BUILD FAILED
      Total time: 2.063 secs
      Error: /project/gradlew: Command failed with exit code 1 Error output:
      * What went wrong:
        9.4.0
        9.2.1
        9.2.0
        9.0.2
        9.0.1
        + 5 more
        file:/project/libs/
        Required by:
      * Try:
        at ChildProcess.whenDone (/project/cordova/node_modules/cordova-common/src/superspawn.js:169:23)
        at emitTwo (events.js:106:13)
        at ChildProcess.emit (events.js:191:7)
        at maybeClose (internal/child_process.js:877:16)
        at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
