4 Replies Latest reply on Nov 2, 2016 6:12 PM by Obi-wan Kenobi
    Can I make two text boxes two columns?
    AnotherMe Level 1
      Is there a way for me to take two text boxes that already have text in them and convert them into one text box with two columns?
        • 1. Re: Can I make two text boxes two columns?
          SJRiegel Adobe Community Professional & MVP
          Not directly, but you can turn the first one into a two-column text box, then link the two. The text from the second box should then be pulled into the first one. You can use a column break to control which text the second column starts with. Second box can then be deleted.
          All that being said, it would probably be easier to cut-and-paste the text from the second box into the first one.
          • 2. Re: Can I make two text boxes two columns?
            John Mensinger Adobe Community Professional & MVP
            Not in any elegant way.
            1. Click the out-port of the first frame, then click in side the second frame to thread them; first-to-second.
            2. Delete one of them. (Now all the text is in a single frame.)
            3. Use the Text Frame Options dialog to set the frame to 2 columns.
            4. Resize and relocate as desired to position the 2 columns.
            • 3. Re: Can I make two text boxes two columns?
              Obi-wan Kenobi Level 5
              Yes! … and it's very simple!
              The only thing to know is the gutter size between the 2 text frames!
              Select the 2 frames:
              … fusion them:
              … convert into "rectangle":
              … and change the frame option: 2 col. and gutter size (see above):
              If indépendant frames, first thread them with Text Stitch!
              • 4. Re: Can I make two text boxes two columns?
                … But if you are as lazy as me, just select the 2 text boxes and do it in one click!
                app.doScript(main, ScriptLanguage.JAVASCRIPT, [], UndoModes.ENTIRE_SCRIPT, "Convert 2 Text Frames to 1 With 2 Columns! …");
                function main ()
                if (app.selection.length == 2)
                        a = app.selection[0];
                        b = app.selection[1];
                        if (a instanceof TextFrame && b instanceof TextFrame)
                                if (a.geometricBounds[0] > b.geometricBounds[0])
                                        a = app.selection[1];
                                        b = app.selection[0];
                                    } else
                                        if (a.geometricBounds[0] == b.geometricBounds[0] && a.geometricBounds[1] > b.geometricBounds[1])
                                        if (a.nextTextFrame == null && b.previousTextFrame == null)
                                                a.nextTextFrame = b;
                var gB_a = a.geometricBounds;
                var gB_b = b.geometricBounds;
                var gutter = (gB_b[1] - gB_a[3]).toFixed(2);
                a.geometricBounds = [gB_a[0], gB_a[1], gB_a[2], gB_b[3]];
                a.textFramePreferences.textColumnCount = 2;
                a.textFramePreferences.textColumnGutter = gutter;
                // ___ (^/) ___
                Based on an original code written 6 years ago [march 2010] by Jongware and shared here:
                http://indesignsecrets.com/topic/is-there-a-script-to-combine-selected-frames-as-threaded- text-40
                Thanks [Jongware]
