5 Replies Latest reply on Nov 8, 2016 1:26 PM by Trevorׅ
    How to make a installer for InDesign extension
    flambert95 Level 1
      Hey guys,
      I don't know what will be the best way to share my extension. I have tried the adobe exchange but the problem is that not all users have permissions for the cc service, that get's the software. is it possible to force this, like you click a button and it asks for permissions, so it's not runnning in the background?
      Or is there another way to deal with it?
        • 1. Re: How to make a installer for InDesign extension
          Trevorׅ Adobe Community Professional
          Your on the wrong forum for this but..
          1) Good for a custom made extension but not for mass distribution. Tell the client to unzip and plonk it in the correct folder.
          2) Slightly more graceful script the above. see my Mac version below.
          3) Tell them to download an installer from http://zxpinstaller.com/
          3.5) You can package the installer if you don't care about ridiculously bloating the size of your extensions
          4) Slightly more graceful script the above. You can have a look at GitHub - CreativeDo/ZXPInstaller: Open Source ZXP Installer for Adobe Extensions
          5) See some other ideas HTML Panels Tips: #10 Packaging / ZXP Installers | Photoshop, etc.
          HTH
          Trevor
          var xFile = File.openDialog("Please select the extension file", function(f){return /zxp$/.test(f.name) || f instanceof Folder})
          if (!xFile) exit();
          xSuffix = ".zxp";
          xSuffix = xFile.name.slice(-4);
          xName = '"' + xFile.name.replace(/\.[^.]+$/,"") + '"';
          zipSource = '"' + xFile.fsName + '"';
          installExtension = """
              tell application "Finder"
                  set tryInstallToUser to true
                  set xFolder to "Library:Application Support:Adobe:CEP:extensions"
                  if tryInstallToUser then
                      -- first try set the User specific location
                      set xPath to POSIX path of ((home as Unicode text) & xFolder)
                      try
                          if not (exists xPath as POSIX file) then do shell script "mkdir -p -m a=rwx " & xPath
                      on error errMsg
                          set xPath to POSIX path of (xFolder as Unicode text)
                      end try
                  else
                  end if
                      set zipSource to quoted form of """ + zipSource + """
                      set xName to """ + xName + """
                          -- process the files
                          set destFolder to ((xPath & "/" & xName) as Unicode text)
                          set zipDestination to quoted form of destFolder
                          -- record file mod date to check that it's changed with installation
                          if exists destFolder as POSIX file then
                              set modDate to do shell script "mdls -name kMDItemFSContentChangeDate " & zipDestination
                              do shell script "rm -fR " & zipDestination
                          else
                              set modDate to "No Date"
                          end if
                          delay 1
                          set installXtn to "unzip -o  " & zipSource & " -d " & zipDestination
                          do shell script installXtn
                              set newModDate to do shell script "mdls -name kMDItemFSContentChangeDate " & zipDestination
                          else
                              set newModDate to false
                          end if
                          if (newModDate is not false) and (modDate is not newModDate) then
                              display notification "Great it looks like the installation was successful. Please restart InDesign"
                          else
                              -- Customize the message as required
                              display notification "Sorry the installation failed."
                          end if
                          delay 1
              end tell
          //installExtension
          app.doScript (installExtension, ScriptLanguage.APPLESCRIPT_LANGUAGE);
          A plain applescript sample is
              set destinationPath to POSIX path of (((home as Unicode text) & "Library:Application Support:Adobe:CEP:extensions") as Unicode text)
              set resourcePath to quoted form of POSIX path of ((((path to me)) as Unicode text) & "Contents:Resources:InDesign_Druckbogen_Vorschau.zip")
              set zipFile to "\"" & destinationPath & "/InDesign_Druckbogen_Vorschau.zip\""
              set zp to destinationPath & "/InDesign_Druckbogen_Vorschau"
              set zipFolder to "\"" & zp & "\""
              do shell script "cp -RfX " & resourcePath & " " & zipFile
              set unzip to "unzip -o  " & zipFile & " -d " & zipFolder
              do shell script unzip
              delay 1
              do shell script "rm " & zipFile
              if exists zp as POSIX file then
                  display notification "Die InDesign Druckbogen Vorschau Erweiterung scheint erfolgreich installiert haben"
              else
                  display notification "Die InDesign Druckbogen Vorschau Verlängerung Erweiterung scheint gescheitert erfolgreich installiert haben"
              end if
              delay 1
          end tell
          • 2. Re: How to make a installer for InDesign extension
            flambert95 Level 1
            Thanks for the reply, but found some minutes ago the approch I will take, I will use the command line tool, that comes with extension manager. But one thing that I can't get to work is my self signed signature, when I test it on another computer without PlayerDebugMode, is it possible to sign it yourself and still be able to use the plugin?
            • 3. Re: How to make a installer for InDesign extension
              Signing is quite easy and certainly still possible (Not checked on CC2017).
              See the link by 5)
              • 4. Re: How to make a installer for InDesign extension
                flambert95 Level 1
                I have the extension signed but still won't work :/ I just get a blank panel
                • 5. Re: How to make a installer for InDesign extension
                  I'm adding this link as it contains some more info (links) of installers and signing
                  GitHub - Adobe-CEP/CEP-Resources: Getting Started with Adobe CC 2014 Extension SDK
                  This is a general beginners link A Short Guide to HTML5 Extensions | Adobe Developer Connection
                  Davide's site HTML Panels | Photoshop, etc.  is a good source of info.
                  HTH
                  Trevor
