0 Replies Latest reply on Nov 3, 2016 1:24 AM by Sudha K
    Set short date format to specific region
    Sudha K Level 1
           I am exporting PDF from InDesign document with date. The pdf contains the 4 digits date format for United Kingdom.  I need to change the year format from 4 digits to 2 digits format.  I don't know how to change that year format.  I have tried the below code. But its writing the static date as wrongly. I think that I have to click and change the year format as image shows.
           How to change the year format?? The text field control contains 3 drop down control.  I could not know how to change that.
           1. Click System Preferences -> Language & Text -> Formats
            2. Set Region value to "United Kingdom"
            3. Click Customize button (1st) and set the year 2016 to 16(2 digits) in short.
      Code:
      global theSettings
      local versName
      set osVersion to do shell script "sw_vers -productVersion"
      set versList to my explode(".", osVersion)
      if (count of versList) > 1 then
          set versName to item 2 of versList as number
      end if
      setRegionValue(versName)
      on setRegionValue(osVers)
          tell application "System Preferences"
              activate
              get the name of every pane of application "System Preferences"
              set the current pane to pane id "com.apple.Localization"
              get the name of every anchor of pane id "com.apple.Localization"
              if osVers ≥ 6 and osVers < 8 then
                  reveal anchor "Formats" of pane id "com.apple.Localization"
              else if osVers ≥ 8 and osVers < 9 then
                  reveal anchor "Region" of pane id "com.apple.Localization"
              else if osVers ≥ 9 then
              else -- Other Versions
              end if
          end tell
          tell application "System Events"
              tell application process "System Preferences"
                  tell window 1
                      if osVers ≥ 6 and osVers < 9 then
                          set the theCountry to "United Kingdom"
                          tell pop up button 1 of tab group 1
                              set regionValue to value of item 1 as string
                              if (regionValue is not equal to theCountry) then
                                  delay 0.25
                                  try
                                      click
                                      click menu item theCountry of menu 1
                                  end try
                              end if
                          end tell
                          set theSettings to {"Americas", "United Kingdom"}
                          tell pop up button 1 of group 1
                              set {theRegion, theCountry} to theSettings
                                  delay 0.25
                                  try
                                      click
                                      click menu item theRegion of menu 1
                                      click menu item theCountry of menu 1 of menu item theRegion of menu 1
                                  end try
                              end if
                          end tell
                      end if
                  end tell
              end tell
                      click button 4 of tab group 1 of window "Language & Text"
                      set dateValue to value of static text 4 of group 1 of tab group 1 of window "Language & Text"
                      set dateList to my explode("/", dateValue)
                      set yr to item 3 of dateList
                      if (count of yr) is equal to 4 then
                          set yr to characters 3 thru -1 of yr as string
                          set item 3 of dateList to yr
                      end if
                      set dateFrmt to my joinAList(dateList, "/")
                      tell static text 4 of group 1 of tab group 1 of window "Language & Text"
                          keystroke dateFrmt -- Here i need to change the year format by click
                          keystroke tab
                          keystroke tab
                          keystroke tab
                          keystroke tab
                          keystroke tab
                          keystroke return
                      end tell
                  end tell
              end tell
              keystroke "w" using {command down}
              quit application "System Preferences"
          end tell
      end setRegionValue
      on explode(delimiter, input)
          local delimiter, input, ASTID
          set ASTID to AppleScript's text item delimiters
          try
              set AppleScript's text item delimiters to delimiter
              set input to text items of input
              set AppleScript's text item delimiters to ASTID
              return input
          on error eMsg number eNum
              error "Can't explode: " & eMsg number eNum
          end try
      end explode
      on joinAList(theList, delim)
          set newString to ""
          set oldDelims to AppleScript's text item delimiters
          set newString to theList as string
          set AppleScript's text item delimiters to oldDelims
          return newString
      end joinAList
      - Sudha K
