I have a from on a document that has a reset button which should clear the form when in Reader however when I export to PDF to test the button it does not work. If I look at the properties in Acrobat and edit the clear form action the are no form fields showing.
I have found previous version of which the pdf works but if i re-export the button doe not work , this would suggest that it is something to do with InDesign updates as i have not modified the file.
Hi Martin
Please share which version of InDesign and Acrobat you are using.
Regards
Anasuiya Gupta
InDesign Team
Hi thanks for your reply
InDesign CC (2017)
Acrobat 15.020.20042
Regards
Ian
Hi Ian
Is it possible for you to share your file with us anasgupt@adobe.com. Please make sure you create a package and then share it.
Regards
Anasuiya Gupta
InDesign Team
Hi
I have emailed you
Did you export the form from InDesign to PDF selecting: Export > Adobe PDF (Interactive) from the Format drop-down menu?
HI Derek
yes I used Interactive pdf
