0 Replies Latest reply on Nov 3, 2016 5:23 AM by Kais Khelif_179
    AEM HTML Forms render
    Kais Khelif_179
      Guys,
      I have a process that uses JDBC query to get data from a SQL Database and put the result in a XML file as a variable. The same process used in PDF render and everything worked great and the drop down populates. We started using HTML5 render for our new forms and I used the exact same process with a JDBC Query and it worked fine but the code that populates the list doesn't seem to work anymore. I will post the function code I am using and I am trying to find out if anything changed the way nodes get resolved in HTML render as appose to the PDF render in the process.
