opensource_ wrote:
> Is there a way to share sessions between ColdFusion and
PHP? I looking for a
> way to use CF and PHP together on the same project? I've
seen a way to run PHP
> within a CF page by using <cf_php> <?php tags
but I'm looking for a way to run
> PHP natively in .php file and still be able to
access/modify CF session
> variables.
The ColdFusion application server does not interfere with
PHP's
application server memory and vice a versa. So no they do not
share
sessions.
That being said, there are relatively simple methods to pass
session
data back and forth. Web services or plain http request
[<cfhttp...>
and|or the PHP equivalent] would be the first things that
occur to my mind.
You'll have to take into count that while the PHP portion of
the
application is running the ColdFusion session timeout is
ticking down as
well as the reverse. If this is a concern, some type of
'heart-beat'
logic would need to be used to call code that keeps to
corresponding
session in the other application server alive.
