Did they remove the ability to resize artboards with the artboard tool? I mean the handles on the edge of the board, similar to the transform handles. Or am I just missing something?
Edit: Found the answer myself: the handles are still there, they are just not displayed
thanks for the tips, must be an error, I don't see how new users or even current will figure this out without searching. Bad UX to my point of view!
It is definitely not obvious at all. It's hidden and out of sight.
Yes had the same issue with the new Photoshop CC2017. However, when I click on the artboard within my layers and set the height option in the Properties panel, the handles come back.
This is Definitely a Glitch!
I can't resize my artboard, only through "Properties"
Very annoying!
Same problem. Incredibly annoying to take away the transform handles from the artboard.
Adobe is going in the wrong direction. I don't if it is because the CEO is not from USA, so they roll out whatever they want ... more like a dictatorship. This is got to be the worst decision that adobe has decided. New Product Manager please. Stop trying to re-event something that has been working for a long time. Your ideas need to be re-shelved. How can you just change something that people have used for many many many years and just like that... . You are crazy. We pay monthly fees to get the best product not a degrading product. Your Product Designer has poor design skills. Fix it !!!!! Your company is becoming less reliable. You are breaking standards to introduce new ideas that actually SUCK!!!!
jonas.r.hoffmann​ and I got this answer from Adobe, it worked for me!
Photoschop CC 2017: Artboard resizing problem | Photoshop Family Customer Community
My artboard transform handles have disappeared as well. Just recently.
The good news is, with the artboard selected with the artboard/move tool, you can hover over the corners of the artboard and see that you get the resize tool.
I much prefer to have my 8 handles back for horizontal and vertical resizing, but at least this technique got me out of trouble.
Hope this helps.
This is tricky, and the behavior certainly changed. Just bring back the handles.
Thanks for the work around.
I had the problem that I could sometimes use the resize handles and sometimes not, but I figured it out and know now how it works:
Hover just next to the sign to the sides of the artboard and there suddenly the resize handles will appear. But only on those 4 very small spots.
It was so frustrating before I figured this out that I might help somebody else by pointing this out.
I friggin HATE PSD Fartboards! ( At least the initial UI hump(in my rump)! )
I've used artboards in Illustrator for ever and just started using one in Photoshop for an animated gif that's based on an Adobe Template file... and I am lost, stuck irritated and wasting valuable time.
Not meaning to be a Troll, but I've been using the Adobe Suites since 1999 and I am banging my head with this... Xxx minutes clunking around trying to figure out how to get around, and just to resize the artboard on my own, before looking for directions here outside of my workflow and project... yuck...
I've used artboards in Illustrator for ever and this is my first time using (failing miserably) artboards in Photoshop for an animated gif that's based on an Adobe Template file... I am lost, stuck irritated and wasting valuable time.
Agreed. Artboards are ANNOYING. At the very least, if I'm trying to crop something, the artboard should change size. Adobe Photoshop, go back to what made you popular to begin with. If we wanted to use Illustrator, we would.
