• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
table position
Community Beginner ,
Nov 03, 2016 Nov 03, 2016
I want to create 5 small tables in a textframe side by side. So I create them this way:
for(var i = 0; i < 5; i++) {
    var table = textFrame.insertionPoints[-1].tables.add();
    table.bodyRowCount = 2;
    table.columnCount = 1;
    table.width = 16;
However, this code positions the tables one below the other and not side by side.
I haven't found out so far how I can achieve this. Help very appreciated.
TOPICS
Scripting
Views
953
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Nov 03, 2016 Nov 03, 2016
Hi together,
yes—using anchored frames is possible.
Here some code:
// Text frame selected:
var textFrame = app.selection[0];
// Let's build a text frame with a table somewhere on the spread:
var frameWithTable = app.documents[0].layoutWindows[0].activeSpread.textFrames.add
        geometricBounds : [0,0,100,16],
        strokeWidth : 0,
        strokeColor : "None",
        fillColor : "None"
// Adding a table:
frameWithTable.insertionPoints[0].tables.add
        bodyRowCount : 2,
Votes
Translate
Translate
Mentor ,
Are you able to do it manually (in GUI)?
Votes
Translate
Translate
Report
Report
No! 🙂
I have tried to pack the tables into textframes but that didn't work well.
Votes
Translate
Translate
Report
Report
LEGEND ,
I've done it into auto-resized text frames! Interesting way!
Votes
Translate
Translate
Report
Report
Community Expert ,
Hi together,
Here some code:
        strokeWidth : 0,
        fillColor : "None"
// Adding a table:
        bodyRowCount : 2,
        columnCount : 1,
        width : 16,
        contents : ["Cell 1", "Cell 2"]
// Let's fit the frame to the table:
frameWithTable.fit(FitOptions.FRAME_TO_CONTENT);
// Duplicate and anchor the duplicates to the selected text frame:
for(var n=0;n<5;n++)
    var dup = frameWithTable.duplicate();
    dup.anchoredObjectSettings.insertAnchoredObject
        textFrame.parentStory.insertionPoints[-1] ,
        AnchorPosition.INLINE_POSITION
    // Maybe we need a separator character between the frames?
    textFrame.parentStory.insertionPoints[-1].contents = " ";
// Remove the frame we built on the spread:
frameWithTable.remove();
Have fun!
Cheers,
Uwe
Votes
Translate
Translate
Report
Report
LEGEND ,
Uwe or Jarek,
A simple question: How can I find tables that follow and catch them (as an array to be exploited later)?
Only interested by tables groups (2, 3, 4, … tables), not isolated (1) table.
Thanks in advance!
Votes
Translate
Translate
Report
Report
Mentor ,
An Array of Tables from anchored textFrames could be called like:
thisTextFrame.textFrames.everyItem().tables
However Uwe's code give us a simple monostructured ones (no isolated...:)
Jarek
PS. Are you detecting Chrome getting frozen while this forum's post editor is fired, guys?
FireFox doing well on my side (Win 10, PC)...
Votes
Translate
Translate
Report
Report
LEGEND ,
Thanks Jarek!
It's the first way for me. I'm working on Uwe's approach.
My 2nd way is to insert tables that follow (as usual in current text) in a new table.
So, I've the same question:  How can I find and catch them?
Thanks in advance!
I don't use Chrome!  😉
Votes
Translate
Translate
Report
Report
Community Expert ,
Nov 04, 2016 Nov 04, 2016
Hi Obi-wan,
I'm not sure what you are asking here.
Do you want to track tables that are inserted with inline anchored text frames?
Example
Find all nested tables in the selected text frame.
Where the depth of nesting is 1 . That means find a table that sits inside an anchored text frame.
The first table in the text frame should not count. It is not nested.
We could do:
app.selection[0].textFrames.everyItem().tables.everyItem().getElements();
That would result in an array of 10 tables.
You could add all "regular" tables in the text frame as well:
var tablesArray = app.selection[0].tables.everyItem().getElements();
var nestedTablesArray = app.selection[0].textFrames.everyItem().tables.everyItem().getElements();
nestedTablesArray.concat(tablesArray);
That array would contain 11 tables.
How deep do you want to nest your tables?
Regards,
Uwe
Votes
Translate
Translate
Report
Report
LEGEND ,
Hi Uwe,
I would like to have an answer to this old topic:
Select several tables …
I mean: in this topic, I wanted to select the 3 tables that follow in a current text frame so that I can place them, one table per cell, in a new table.
The deal is to "horizontally" place following tables, eventually "marked" with a condition or a specific para style.
The way you propose with "inline" text frames is an excellent other way I take too.
I would like to have the 2 layout options depending on the layout context.
Votes
Translate
Translate
Report
Report
Community Expert ,
Hi Obi-wan,
hm yes, that would work either way. Just single out the text with the three tables and work with the special characters that hold the tables. Would you want to get the tables from that text by text.tables.everyItem().getElements() and loop through the array to get the character that you'd like to move? Or would you like to do a Text Search with special character <0016> on the text?
But: Since your case is more special than the OP's one, I suggest we maybe should continue to discuss your problems in a different thread. Let's have the original poster—martine55225436—the say on that.
Regards,
Uwe
Votes
Translate
Translate
Report
Report
LEGEND ,
Uwe,
I answer you and then we could go on on my old topic!
In a layout, I could need to horizontally place following tables but not systematically (for different reasons).
So, my idea is to manually apply a condition to the "table support" para and so "mark the tables to be treated.
When done, I launch the script that loops through the doc to find these "conditional" paras containing each a table!
At this step, 2 options: yours or mine!
Imho, yours could be lighter and more interesting, but it depends on the context!
Maybe, 2 conditions to manage the 2 ways! Of course, in the same script!
I don't want you to write the script. However, your help could be great (Jarek and Kai too!) to validate my code writing!!
Last comment on this point here! Next at:  Select several tables …
Votes
Translate
Translate
Report
Report
LEGEND ,
Jarek,
I would be very interested by a way to do it!
I thought about 2 ways: insert them into another table or place them into anchored inline text frames!
Votes
Translate
Translate
Report
Report
Enthusiast ,
Sadly it would be possible for 4, not 5 tables, with the spaning columns feature: Split 4
Votes
Translate
Translate
Report
Report
LEGEND ,
Hi Kai,
The problem with Uwe's way (anchored inline text frames) and yours (span feature) is that we can't correctly control the horizontal space between the tables. It's a reason for me to have the other option!
Votes
Translate
Translate
Report
Report
Community Expert ,
Oh we can control the positions.
By using tabulators perhaps.
Regards,
Uwe
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
Yeap! I think too but not really easy! use insets management in the "layout table" could be cooler!
Votes
Translate
Translate
Report
Report
