1. Re: Plugin is silently skipped if it fails the cordova requirement
simon.macdonaldNov 4, 2016 5:15 AM (in response to phonegapps)
Well two things, one that's not exactly silent as you do get a warning message and two that would be a change to the behaviour of PhoneGap/Cordova which is not something we can really do in a forum. Better to raise an issue at:
2. Re: Plugin is silently skipped if it fails the cordova requirement
ioannis.cherouvim Nov 4, 2016 7:17 AM (in response to simon.macdonald)The build is successful so the application may fail on runtime. Sorry mate, but that's pretty silent
3. Re: Plugin is silently skipped if it fails the cordova requirement
phonegapps Nov 6, 2016 7:07 PM (in response to simon.macdonald)As ioannis.cherouvim said, it's quite silent as the app was successfully compiled but wasn't working correctly. I only check the logs on PGB if there's an error.
So this is a Cordova issue? I would have thought it's linked to PGB. Anyway I feel like it's the normal thing to do to make the build fail, else the user expects everything to be fine, which is never the case if a plugin is not included.
Also I posted in this forum as that's what's written on GitHub - phonegap/build: This is the public repository for PhoneGap Build source and bug tracking If indeed it's a Cordova issue, I'll add something in their JIRA.
4. Re: Plugin is silently skipped if it fails the cordova requirement
simon.macdonaldNov 7, 2016 4:05 AM (in response to phonegapps)
It is 100% a Cordova issue. Please raise the issue on the Cordova bug tracker. This is the same behaviour whether you use PGB or the Cordova CLI.
In the meantime you can upgrade the cordova, cordova-android and cordova-ios versions or stick with version 1.8.4.
5. Re: Plugin is silently skipped if it fails the cordova requirement
phonegapps Nov 7, 2016 7:59 PM (in response to simon.macdonald)Thanks Simon,
[CB-12122] Incompatible plugin should make the build fail, not be skipped silently - ASF JIRA
In the meantime I indeed reverted back to 1.8.4.
6. Re: Plugin is silently skipped if it fails the cordova requirement
simon.macdonaldNov 8, 2016 4:30 AM (in response to phonegapps)
Thanks, I've started watching the issue and we are already discussing it on the dev mailing list. Issues like this have more weight when they come from the community.
7. Re: Plugin is silently skipped if it fails the cordova requirement
benjamino96587917 Nov 19, 2016 4:00 AM (in response to phonegapps)I have the same issue even though it clearly says my app has been built with cli-6.4.0.
My config.xml:
My app's page on PGB:
logs from PGB:
Fetching plugin "phonegap-plugin-push" via npm
Installing "phonegap-plugin-push" at "1.9.0" for android
Plugin doesn't support this project's cordova version. cordova: 6.3.2, failed version requirement: >=6.4.0
Skipping 'phonegap-plugin-push' for androidSupported cli versions by PGB:
For now I'll be rolling back to 1.8.4.
8. Re: Plugin is silently skipped if it fails the cordova requirement
joinupd74230013 Dec 16, 2016 12:36 AM (in response to benjamino96587917)Now the push plugin (version 1.8.4) does not work in iOS10... so now it is not a solution rolling back to 1.8.4.
9. Re: Plugin is silently skipped if it fails the cordova requirement
simon.macdonaldDec 16, 2016 7:18 AM (in response to joinupd74230013)
Please try 1.9.1 with PGB now. The team made some changes yesterday which should resolve the issue. Please let me know if it works for you.
10. Re: Plugin is silently skipped if it fails the cordova requirement
joinupd74230013 Dec 19, 2016 1:06 AM (in response to simon.macdonald)Same error :-(
1.9.1 version:
Repository "https://github.com/phonegap/phonegap-plugin-push.git" checked out to git ref "v1.9.1" at "6178688".
Installing "phonegap-plugin-push" at "1.9.1" for ios
1.9.2 version:
Repository "https://github.com/phonegap/phonegap-plugin-push.git" checked out to git ref "v1.9.2" at "ef3de32".
Installing "phonegap-plugin-push" at "1.9.2" for ios
Is there a way to set cordova version? It seems this does not work:
<engine name="ios" spec="4.3.0" />
<preference name="phonegap-version" value="cli-6.4.0" />
Other important lines:
<plugin name="phonegap-plugin-push" spec="https://github.com/phonegap/phonegap-plugin-push.git#v1.9.1" source="git">
<param name="SENDER_ID" value="XXXXXX" />
</plugin>
