8 Replies Latest reply on Nov 20, 2016 1:06 AM by scon2016
    Building error on phonegap CLI
    scon2016
      Dear users,
      when I try to build an app with "phonegap build android --debug", I receive this error:
      root@m-ub:/srv/applicazioni/ddns# phonegap build android --debug
      [phonegap] executing 'cordova build android --debug ' ...
      ANDROID_HOME=/usr/local/android-sdk-linux/
      JAVA_HOME=/usr/lib/jvm/java-7-openjdk-i386
      FAILURE:
      Build failed with an exception.
      * What went wrong:
      A problem occurred configuring root project 'android'.
      > failed to find target with hash string '15' in: /usr/local/android-sdk-linux
      * Try:
      Run with --stacktrace option to get the stack trace. Run with --info
      or
      --debug
      option to get more log output.
      BUILD FAILED
      Total time: 2.902 secs
      Error: Error code 1 for command: /srv/applicazioni/ddns/platforms/android/gradlew with args: cdvBuildDebug,-b,/srv/applicazioni/ddns/platforms/android/build.gradle,-Dorg.gradle.daemo n=true,-Pandroid.useDeprecatedNdk=true
      I have created 3 environment variables with a file in /root directory:
      export ANDROID_HOME=/usr/local/android-sdk-linux/
      export PATH=${PATH}:/usr/local/android-sdk-linux/platform-tools:/usr/local/android-sdk-linux/too ls
      export ORG_GRADLE_PROJECT_cdvCompileSdkVersion=15
      How can I fix this issue?
        • 1. Re: Building error on phonegap CLI
          ShazronAbdullah Adobe Employee
          Need more info:
          1. What version of the phonegap CLI are you running?
          2. What version of the cordova-android platform are you running?
          3. I assume API level 15 platform is installed in Android SDK Manager?
          • 2. Re: Building error on phonegap CLI
            scon2016 Level 1
            Phonegap CLI version: 6.3.4
            This is the result when I execute "phonegap info" in the directory where there is my app:
            root@m-ub:/srv/applicazioni/ddns# phonegap info
            Collecting Data...
            Node version: v0.10.25
            Cordova version: 6.1.1
            Config.xml file:
            <?xml version='1.0' encoding='utf-8'?>
            <widget id="com.miosito.ddns" version="1.0.0" xmlns="http://www.w3.org/ns/widgets" xmlns:gap="http://phonegap.com/ns/1.0">
                <name>Controllo DDNS</name>
                <description>
                    Hello World sample application that responds to the deviceready event.
                </description>
                <author email="support@phonegap.com" href="http://phonegap.com">
                    PhoneGap Team
                </author>
                <content src="index.html" />
                <preference name="DisallowOverscroll" value="true" />
                <preference name="android-minSdkVersion" value="14" />
                <plugin name="cordova-plugin-battery-status" source="npm" spec="~1.1.1" />
                <plugin name="cordova-plugin-camera" source="npm" spec="~2.1.1" />
                <plugin name="cordova-plugin-media-capture" source="npm" spec="~1.2.0" />
                <plugin name="cordova-plugin-console" source="npm" spec="~1.0.2" />
                <plugin name="cordova-plugin-contacts" source="npm" spec="~2.0.1" />
                <plugin name="cordova-plugin-device" source="npm" spec="~1.1.1" />
                <plugin name="cordova-plugin-device-motion" source="npm" spec="~1.2.0" />
                <plugin name="cordova-plugin-device-orientation" source="npm" spec="~1.0.2" />
                <plugin name="cordova-plugin-dialogs" source="npm" spec="~1.2.0" />
                <plugin name="cordova-plugin-file" source="npm" spec="~4.1.1" />
                <plugin name="cordova-plugin-file-transfer" source="npm" spec="~1.5.0" />
                <plugin name="cordova-plugin-geolocation" source="npm" spec="~2.1.0" />
                <plugin name="cordova-plugin-globalization" source="npm" spec="~1.0.3" />
                <plugin name="cordova-plugin-inappbrowser" source="npm" spec="~1.3.0" />
                <plugin name="cordova-plugin-media" source="npm" spec="~2.2.0" />
                <plugin name="cordova-plugin-network-information" source="npm" spec="~1.2.0" />
                <plugin name="cordova-plugin-splashscreen" source="npm" spec="~3.2.1" />
                <plugin name="cordova-plugin-statusbar" source="npm" spec="~2.1.2" />
                <plugin name="cordova-plugin-vibration" source="npm" spec="~2.1.0" />
                <plugin name="cordova-plugin-whitelist" source="npm" spec="~1.2.1" />
                <icon src="icon.png" />
                <platform name="android">
                    <icon density="ldpi" src="www/res/icon/android/drawable-ldpi-icon.png" />
                    <icon density="mdpi" src="www/res/icon/android/drawable-mdpi-icon.png" />
                    <icon density="hdpi" src="www/res/icon/android/drawable-hdpi-icon.png" />
                    <icon density="xhdpi" src="www/res/icon/android/drawable-xhdpi-icon.png" />
                    <icon density="xxhdpi" src="www/res/icon/android/drawable-xxhdpi-icon.png" />
                    <icon density="xxxhdpi" src="www/res/icon/android/drawable-xxxhdpi-icon.png" />
                    <splash density="land-ldpi" src="www/res/screen/android/drawable-land-ldpi-screen.png" />
                    <splash density="land-mdpi" src="www/res/screen/android/drawable-land-mdpi-screen.png" />
                    <splash density="land-hdpi" src="www/res/screen/android/drawable-land-hdpi-screen.png" />
                    <splash density="land-xhdpi" src="www/res/screen/android/drawable-land-xhdpi-screen.png" />
                    <splash density="land-xxhdpi" src="www/res/screen/android/drawable-land-xxhdpi-screen.png" />
                    <splash density="land-xxxhdpi" src="www/res/screen/android/drawable-land-xxxhdpi-screen.png" />
                    <splash density="port-ldpi" src="www/res/screen/android/drawable-port-ldpi-screen.png" />
                    <splash density="port-mdpi" src="www/res/screen/android/drawable-port-mdpi-screen.png" />
                    <splash density="port-hdpi" src="www/res/screen/android/drawable-port-hdpi-screen.png" />
                    <splash density="port-xhdpi" src="www/res/screen/android/drawable-port-xhdpi-screen.png" />
                    <splash density="port-xxhdpi" src="www/res/screen/android/drawable-port-xxhdpi-screen.png" />
                    <splash density="port-xxxhdpi" src="www/res/screen/android/drawable-port-xxxhdpi-screen.png" />
                </platform>
                <platform name="ios">
                    <icon height="57" platform="ios" src="www/res/icon/ios/icon.png" width="57" />
                    <icon height="114" platform="ios" src="www/res/icon/ios/icon@2x.png" width="114" />
                    <icon height="40" platform="ios" src="www/res/icon/ios/icon-40.png" width="40" />
                    <icon height="80" platform="ios" src="www/res/icon/ios/icon-40@2x.png" width="80" />
                    <icon height="50" platform="ios" src="www/res/icon/ios/icon-50.png" width="50" />
                    <icon height="100" platform="ios" src="www/res/icon/ios/icon-50@2x.png" width="100" />
                    <icon height="60" platform="ios" src="www/res/icon/ios/icon-60.png" width="60" />
                    <icon height="120" platform="ios" src="www/res/icon/ios/icon-60@2x.png" width="120" />
                    <icon height="180" platform="ios" src="www/res/icon/ios/icon-60@3x.png" width="180" />
                    <icon height="72" platform="ios" src="www/res/icon/ios/icon-72.png" width="72" />
                    <icon height="144" platform="ios" src="www/res/icon/ios/icon-72@2x.png" width="144" />
                    <icon height="76" platform="ios" src="www/res/icon/ios/icon-76.png" width="76" />
                    <icon height="152" platform="ios" src="www/res/icon/ios/icon-76@2x.png" width="152" />
                    <icon height="29" platform="ios" src="www/res/icon/ios/icon-small.png" width="29" />
                    <icon height="58" platform="ios" src="www/res/icon/ios/icon-small@2x.png" width="58" />
                    <icon height="87" platform="ios" src="www/res/icon/ios/icon-small@3x.png" width="87" />
                    <splash height="1136" platform="ios" src="www/res/screen/ios/Default-568h@2x~iphone.png" width="640" />
                    <splash height="1334" platform="ios" src="www/res/screen/ios/Default-667h.png" width="750" />
                    <splash height="2208" platform="ios" src="www/res/screen/ios/Default-736h.png" width="1242" />
                    <splash height="1242" platform="ios" src="www/res/screen/ios/Default-Landscape-736h.png" width="2208" />
                    <splash height="1536" platform="ios" src="www/res/screen/ios/Default-Landscape@2x~ipad.png" width="2048" />
                    <splash height="768" platform="ios" src="www/res/screen/ios/Default-Landscape~ipad.png" width="1024" />
                    <splash height="2048" platform="ios" src="www/res/screen/ios/Default-Portrait@2x~ipad.png" width="1536" />
                    <splash height="1024" platform="ios" src="www/res/screen/ios/Default-Portrait~ipad.png" width="768" />
                    <splash height="960" platform="ios" src="www/res/screen/ios/Default@2x~iphone.png" width="640" />
                    <splash height="480" platform="ios" src="www/res/screen/ios/Default~iphone.png" width="320" />
                </platform>
                <platform name="wp8">
                    <icon height="99" platform="wp8" src="www/res/icon/wp8/ApplicationIcon.png" width="99" />
                    <icon height="159" platform="wp8" src="www/res/icon/wp8/Background.png" width="159" />
                    <splash height="1280" platform="wp8" src="www/res/screen/wp8/screen-portrait.jpg" width="768" />
                </platform>
                <platform name="windows">
                    <icon height="150" platform="windows" src="www/res/icon/windows/Square150x150Logo.scale-100.png" width="150" />
                    <icon height="30" platform="windows" src="www/res/icon/windows/Square30x30Logo.scale-100.png" width="30" />
                    <icon height="50" platform="windows" src="www/res/icon/windows/StoreLogo.scale-100.png" width="50" />
                    <splash height="300" platform="windows" src="www/res/screen/windows/SplashScreen.scale-100.png" width="620" />
                    <icon height="120" platform="windows" src="www/res/icon/windows/StoreLogo.scale-240.png" width="120" />
                    <icon height="44" platform="windows" src="www/res/icon/windows/Square44x44Logo.scale-100.png" width="44" />
                    <icon height="106" platform="windows" src="www/res/icon/windows/Square44x44Logo.scale-240.png" width="106" />
                    <icon height="70" platform="windows" src="www/res/icon/windows/Square70x70Logo.scale-100.png" width="70" />
                    <icon height="71" platform="windows" src="www/res/icon/windows/Square71x71Logo.scale-100.png" width="71" />
                    <icon height="170" platform="windows" src="www/res/icon/windows/Square71x71Logo.scale-240.png" width="170" />
                    <icon height="360" platform="windows" src="www/res/icon/windows/Square150x150Logo.scale-240.png" width="360" />
                    <icon height="310" platform="windows" src="www/res/icon/windows/Square310x310Logo.scale-100.png" width="310" />
                    <icon height="150" platform="windows" src="www/res/icon/windows/Wide310x150Logo.scale-100.png" width="310" />
                    <icon height="360" platform="windows" src="www/res/icon/windows/Wide310x150Logo.scale-240.png" width="744" />
                    <splash height="1920" platform="windows" src="www/res/screen/windows/SplashScreenPhone.scale-240.png" width="1152" />
                </platform>
                <access origin="*" />
                <allow-intent href="http://*/*" />
                <allow-intent href="https://*/*" />
                <allow-intent href="tel:*" />
                <allow-intent href="sms:*" />
                <allow-intent href="mailto:*" />
                <allow-intent href="geo:*" />
                    <allow-intent href="market:*" />
                </platform>
                    <allow-intent href="itms:*" />
                    <allow-intent href="itms-apps:*" />
                </platform>
            </widget>
            Plugins:
            cordova-plugin-battery-status,cordova-plugin-camera,cordova-plugin-compat,cordova-plugin-c onsole,cordova-plugin-contacts,cordova-plugin-device,cordova-plugin-device-motion,cordova- plugin-device-orientation,cordova-plugin-dialogs,cordova-plugin-file,cordova-plugin-file-t ransfer,cordova-plugin-geolocation,cordova-plugin-globalization,cordova-plugin-inappbrowse r,cordova-plugin-media,cordova-plugin-media-capture,cordova-plugin-network-information,cor dova-plugin-splashscreen,cordova-plugin-statusbar,cordova-plugin-vibration,cordova-plugin- whitelist
            Android platform:
            Available Android targets:
            id: 1 or "android-7"
                 Type: Platform
                 API level: 7
                 Revision: 3
                 Skins: HVGA, QVGA, WQVGA400, WQVGA432, WVGA800 (default), WVGA854
            Tag/ABIs : default/armeabi
            id: 2 or "android-8"
                 Type: Platform
                 API level: 8
                 Revision: 3
            id: 3 or "android-9"
                 Type: Platform
                 API level: 9
                 Revision: 2
            id: 4 or "android-10"
                 Type: Platform
                 API level: 10
                 Revision: 2
            id: 5 or "android-11"
                 Type: Platform
                 API level: 11
                 Revision: 2
                 Skins: WXGA (default)
            id: 6 or "android-12"
                 Type: Platform
                 API level: 12
                 Revision: 3
            id: 7 or "android-13"
                 Type: Platform
                 API level: 13
                 Revision: 1
            id: 8 or "android-14"
                 Type: Platform
                 API level: 14
                 Revision: 4
                 Skins: HVGA, QVGA, WQVGA400, WQVGA432, WSVGA, WVGA800 (default), WVGA854, WXGA720, WXGA800
            Tag/ABIs : no ABIs.
            id: 9 or "android-15"
                 Type: Platform
                 API level: 15
                 Revision: 5
            Tag/ABIs : no ABIs.
            id: 10 or "android-16"
                 Type: Platform
                 API level: 16
                 Revision: 5
                 Skins: HVGA, QVGA, WQVGA400, WQVGA432, WSVGA, WVGA800 (default), WVGA854, WXGA720, WXGA800, WXGA800-7in
            Tag/ABIs : no ABIs.
            id: 11 or "android-17"
                 Type: Platform
                 API level: 17
                 Revision: 3
            Tag/ABIs : no ABIs.
            id: 12 or "android-18"
                 Type: Platform
                 API level: 18
                 Revision: 3
            Tag/ABIs : no ABIs.
            id: 13 or "android-19"
                 Type: Platform
                 API level: 19
                 Revision: 4
            Tag/ABIs : no ABIs.
            id: 14 or "android-20"
                 Type: Platform
                 API level: 20
                 Revision: 2
            Tag/ABIs : no ABIs.
            id: 15 or "android-21"
                 Type: Platform
                 API level: 21
                 Revision: 2
            Tag/ABIs : no ABIs.
            id: 16 or "android-22"
                 Type: Platform
                 API level: 22
                 Revision: 2
            Tag/ABIs : no ABIs.
            id: 17 or "android-23"
                 Type: Platform
                 API level: 23
                 Revision: 3
            Tag/ABIs : no ABIs.
            id: 18 or "android-24"
                 Type: Platform
                 API level: 24
                 Revision: 2
            Tag/ABIs : no ABIs.
            id: 19 or "android-25"
                 Type: Platform
                 API level: 25
                 Revision: 1
            Tag/ABIs : no ABIs.
            id: 20 or "Google Inc.:Google APIs:15"
                 Type: Add-On
                 Vendor: Google Inc.
                 Revision: 3
                 Description: Android + Google APIs
                 Based on Android 4.0.3 (API level 15)
                 Libraries:
                  * com.google.android.media.effects (effects.jar)
                      Collection of video effects
                  * com.android.future.usb.accessory (usb.jar)
                      API for USB Accessories
                  * com.google.android.maps (maps.jar)
                      API for Google Maps
            Tag/ABIs : default/armeabi-v7a
            id: 21 or "Google Inc.:Google APIs:16"
                 Type: Add-On
                 Vendor: Google Inc.
                 Revision: 4
                 Based on Android 4.1.2 (API level 16)
                 Libraries:
                      API for Google Maps
            id: 22 or "Google Inc.:Google APIs:17"
                 Type: Add-On
                 Vendor: Google Inc.
                 Revision: 4
                 Based on Android 4.2.2 (API level 17)
                 Libraries:
                      API for Google Maps
            id: 23 or "Google Inc.:Google APIs:18"
                 Type: Add-On
                 Vendor: Google Inc.
                 Revision: 4
                 Based on Android 4.3.1 (API level 18)
                 Libraries:
                      API for Google Maps
            id: 24 or "Google Inc.:Glass Development Kit Preview:19"
                 Name: Glass Development Kit Preview
                 Type: Add-On
                 Vendor: Google Inc.
                 Revision: 11
                 Description: Preview of the Glass Development Kit
                 Based on Android 4.4.2 (API level 19)
                 Libraries:
                  * com.google.android.glass (gdk.jar)
                      APIs for Glass Development Kit Preview
            Tag/ABIs : no ABIs.
            id: 25 or "Google Inc.:Google APIs:19"
                 Type: Add-On
                 Vendor: Google Inc.
                 Revision: 20
                 Libraries:
                      API for Google Maps
            Tag/ABIs : no ABIs.
            id: 26 or "Google Inc.:Google APIs:21"
                 Type: Add-On
                 Vendor: Google Inc.
                 Revision: 1
                 Based on Android 5.0.1 (API level 21)
                 Libraries:
                      API for Google Maps
            Tag/ABIs : no ABIs.
            id: 27 or "Google Inc.:Google APIs:22"
                 Type: Add-On
                 Vendor: Google Inc.
                 Revision: 1
                 Based on Android 5.1.1 (API level 22)
                 Libraries:
                      API for Google Maps
            Tag/ABIs : no ABIs.
            id: 28 or "Google Inc.:Google APIs:23"
                 Type: Add-On
                 Vendor: Google Inc.
                 Revision: 1
                 Based on Android 6.0 (API level 23)
                 Libraries:
                      API for Google Maps
            Tag/ABIs : no ABIs.
            id: 29 or "Google Inc.:Google APIs:24"
                 Type: Add-On
                 Vendor: Google Inc.
                 Revision: 1
                 Based on Android 7.0 (API level 24)
                 Libraries:
                      API for Google Maps
            Tag/ABIs : no ABIs.
            I want to know how I can fix this issue.
            • 3. Re: Building error on phonegap CLI
              Your config.xml does not tell me what cordova-android version you are running. `cordova platform save` should do it.
              Did you:
              1. run a clean and try the build again?
              2. do a bunch of upgrades on the project (how old is the project)?
              • 4. Re: Building error on phonegap CLI
                scon2016 Level 1
                This is the result when I enter the command "phonegap cordova clean":
                root@m-ub:/srv/applicazioni/ddns# phonegap cordova clean
                FAILURE:
                * What went wrong:
                * Try:
                or
                --debug option to get more log output.
                BUILD FAILED
                Total time: 2.879 secs
                Error: /srv/applicazioni/ddns/platforms/android/gradlew: Command failed with exit code 1
                When I enter "phonegap cordova platform save", I don't have any output.
                The project is old 2 weeks.
                Can you help me to fix this issue?
                • 5. Re: Building error on phonegap CLI
                  Sorry, don't run both "phonegap" and "cordova", just use "phonegap platform save", and re-attach the updated config.xml.
                  • 6. Re: Building error on phonegap CLI
                    scon2016 Level 1
                    I tried it, it's the same. I have changed some data in config.xml (icons files), but when I execute this:
                    phonegap clean
                    phonegap info
                    I get the same config.xml as before.
                    I tried to execute this:
                    cd /usr/local/android-sdk-linux/tools
                    ./android
                    But I got this error:
                    Exception in thread "main" org.eclipse.swt.SWTError: No more handles [gtk_init_check() failed]
                      at org
                    .eclipse.swt.SWT.error(Unknown Source)
                      at org
                    .eclipse.swt.widgets.Display.createDisplay(Unknown Source)
                      at org
                    .eclipse.swt.widgets.Display.create(Unknown Source)
                      at org
                    .eclipse.swt.graphics.Device.<init>(Unknown Source)
                      at org
                    .eclipse.swt.widgets.Display.<init>(Unknown Source)
                      at org
                      at org
                    .eclipse.swt.widgets.Display.getDefault(Unknown Source)
                      at org
                    .eclipse.swt.widgets.Shell.<init>(Unknown Source)
                      at org
                      at com
                    .android.sdkuilib.internal.repository.ui.SdkUpdaterWindowImpl2.createShell(SdkUpdaterWindowImpl2.java:168)
                      at com
                    .android.sdkuilib.internal.repository.ui.SdkUpdaterWindowImpl2.open(SdkUpdaterWindowImpl2.java:137)
                      at com
                    .android.sdkuilib.repository.SdkUpdaterWindow.open(SdkUpdaterWindow.java:111)
                      at com
                    .android.sdkmanager.Main.showSdkManagerWindow(Main.java:356)
                      at com
                    .android.sdkmanager.Main.doAction(Main.java:334)
                      at com
                    .android.sdkmanager.Main.run(Main.java:120)
                      at com
                    .android.sdkmanager.Main.main(Main.java:103)
                    I searched this problem on the internet, and I found that the problem is the version of my OS, only server, not desktop.
                    I don't know how to continue.
                    Can you help?
                    • 8. Re: Building error on phonegap CLI
                      scon2016 Level 1
                      I tried to install all I have installed on my VPS (ubuntu server) on my ubuntu desktop PC, if there was a need of the desktop for some commands.
                      Then I read the page you linked to me and I run these commands:
                      apt-get install xvfb
                      export DISPLAY=:1
                      Xvfb :1 -ac -screen 0 1024x768x8
                      But I had to press "Ctrl+C" to stop the command, beacuse I wasn't able to execute other commands, and then I executed this:
                      ./android
                      But I had this result:
                      Xlib:  extension "RANDR" missing on display ":1".
                      And I had to press "Ctrl+C" to stop the command, and the terminal continued to show this:
                      g_dbus_connection_real_closed: Remote peer vanished with error: Underlying GIOStream returned 0 bytes on an async read (g-io-error-quark, 0). Exiting.
                      root@m-ub:/usr/local/android-sdk-linux/tools# 8 XSELINUXs still allocated at reset
                      SCREEN: 0 objects of 144 bytes = 0 total bytes 0 private allocs
                      DEVICE: 0 objects of 64 bytes = 0 total bytes 0 private allocs
                      CLIENT: 0 objects of 100 bytes = 0 total bytes 0 private allocs
                      WINDOW: 0 objects of 16 bytes = 0 total bytes 0 private allocs
                      PIXMAP: 2 objects of 8 bytes = 16 total bytes 0 private allocs
                      GC: 4 objects of 8 bytes = 32 total bytes 0 private allocs
                      CURSOR: 1 objects of 4 bytes = 4 total bytes 0 private allocs
                      TOTAL: 7 objects, 52 bytes, 0 allocs
                      1 SELECTIONs still allocated at reset
                      2 PIXMAPs still allocated at reset
                      4 GCs still allocated at reset
                      TOTAL: 5 objects, 36 bytes, 0 allocs
                      1 CURSORs still allocated at reset
                      TOTAL: 1 objects, 4 bytes, 0 allocs
                      1 CURSOR_BITSs still allocated at reset
                      TOTAL: 0 objects, 0 bytes, 0 allocs
                      [dix] Could not init font path element /usr/share/fonts/X11/cyrillic, removing from list!
                      [dix] Could not init font path element /usr/share/fonts/X11/100dpi/:unscaled, removing from list!
                      [dix] Could not init font path element /usr/share/fonts/X11/75dpi/:unscaled, removing from list!
                      [dix] Could not init font path element /usr/share/fonts/X11/100dpi, removing from list!
                      [dix] Could not init font path element /usr/share/fonts/X11/75dpi, removing from list!
                      I don't know how to continue, I simply need to build an android app on my VPS.
                      Help!
