1 Reply Latest reply on Dec 12, 2008 11:46 AM by san_flash
    Flash CS3 64-bit will not open once it is closed
    stb12
      The issue that I am having is with Flash CS3 installed on Windows XP 64-bit. A user will open Flash and use it for awhile and then quit the application. Even after the application is closed it still shows up as running a process in the background called Flash. If that user logs off and another logs on Flash will not open for the user. The computer needs to be restarted in order to access Flash again. This does not happen all the time, just an intermittent issue. Does anyone have any ideas on what may be causing this?
