Has the new release (Nov 2016) of Adobe Draw forgotten how to delete a document from a Project?
Projects can be deleted.
When you select a document that is part of a project, no trash can appears in the bottom left corner. There doesn't seem to be user interface available to simply delete a document (perhaps this is just on an iPad Pro).
The steps are:
But once you have a document or multiple documents selected, there is no UI to delete the selected documents.
Thanks DW.
I'll let the product team know about this first thing tomorrow (I'm using the smaller Pro too).
Thanks for posting about this.
Sue.
Hi DW.
It sounds like you may be missing the last step... After you tap "Select Document" from the dropdown menu, it's necessary still to tap on the document that you're trying to Delete (trash can), Duplicate (two squares and +) or Move (document with arrow). That will bring up those options in the lower navigation.
Let me know if that helps.
Sue.
Hi Sue
I think this is a bug. There is no lower navigation visible.
Here's a screen shot. There is an empty white bar across the bottom (which has been the navigation bar for other apps). The document is selected. No trash can or other icons present.
Changing orientation doesn't trigger any update of the UI.
Same behaviour for Adobe Sketch.
DW.
OK. Wow. Yep. That's definitely not right. To eliminate it being a bad installation, can you try uninstalling, restarting your device, then reinstalling the app?
Before you do that though, log in with your Adobe ID to Adobe Creative Cloud and make sure all your work is synced to Creative Cloud. Don't uninstall the app until everything's synced.
Let me know what happens.
Sue.
It's definitely an iPad Pro 12.7" bug. I've just pulled Adobe Draw down onto 9" screen and the menus appear as expected.
Thanks DW.
Sue.
Deleting the app on the iPad Pro 12" and reinstalling fixed the problem.
Thanks, Sue.
DW.
Great. Thanks for letting me know. Still, as you say, sounds like a bug.
Thanks again.
Sue.
There was no need to restart.
Thanks, Sue.
Here's the summary.
On an iPad Pro 12", Adobe Draw (and Sketch) may lose the icon menus at the bottom of the Project Documents screen after the Nov 2016 update. (Version 3.4)
Without these buttons you cannot delete, duplicate or move the selected documents contained within a project.
To rectify this you need to:
DW.
Thanks again.
Sue.
