1 Reply Latest reply on Nov 6, 2016 11:45 AM by Jump_Over
    Code to be evaluated! [006] // Create round corner table(s)! …
    Obi-wan Kenobi Level 5
      Hi all Scripters!
      Depending on what is the target (doc, story, one table or tables contained in a text selection), this code is supposed to round table corners"!
      At the moment, it just round my brain pea!!  In other words, nothing happens!!!
      Ideas?!
      [note: The text frame that receives the table has a "RoundCornerTable" object style whose an option is "round corners"!]
      Thanks as usual for any help!
      app.scriptPreferences.userInteractionLevel = UserInteractionLevels.interactWithAll;
      app.doScript(main, ScriptLanguage.JAVASCRIPT, [], UndoModes.ENTIRE_SCRIPT, "Round Corners Tables! …" );
      function main()
      (function () {
          function getTables () {
              if (app.selection.length == 0) return app.documents[0].stories.everyItem().tables.everyItem().getElements();
              else if (app.selection[0].tables.length > 0) return app.selection[0].tables.everyItem().getElements();
              else if (app.selection[0].parent instanceof Cell) return [app.selection[0].parent.parent];
              else if (app.selection[0].hasOwnProperty ('parentStory')) return app.selection[0].parentStory.tables.everyItem().getElements();
          function RoundCornerTables (tables) {
              for (var t = tables.length-1; t >= 0; t--) {
                      var scores = app.documents[0].stories.everyItem().characters[tables[t].storyOffset.index];
                      frame = scores.insertionPoints[-1].textFrames.add();
                      scores[t].characters.itemByRange (0, scores[t].characters.length-2).move (LocationOptions.after, frame.insertionPoints[0]);
                      frame.applyObjectStyle (myDoc.objectStyles.item('RoundCornerTable'));
          if (app.documents.length > 0)  RoundCornerTables (getTables());
      PS: Even if somebody fixes my issue, the script is not finished!
      Last question: Why, when I place a table (no external stroke) in a text frame with round corners, do we see little white "gaps"?
      See "red" stroke table!  For the "green" stroke table, I used another way!
      Zoom:
        • 1. Re: Code to be evaluated! [006] // Create round corner table(s)! …
          Jump_Over Level 5
          About getTables():
          I can see some misses here:
          • case 2 and 4 do almost the same ( if text selected)
          • if user select a part of table (cells, column) - no case to return
          I suggest to clarify a target for your script.
          Assuming the target is an array of tables ==> lets switch
          case 'text inside a table OR table OR part of table selected': return 1-element array with THIS table only
          case 'text outside table is selected': return an array with every table found in entire parentStory
          case 'textFrame is selected': return array of tables located in this textFrame only
          otherwise: return every table found in a doc (array)
          It shouldn't be a problem to switch by selection properties (alike you do with some modification)
          About RoundCornerTables()
          Assuming there is an array of table returned as input to 2nd function.
          1 question - which version of InDesign is in use? Does it allow method textFrame.add() for insertionPoint object? CS5 doesnt.
          2nd question - why do you set a var scores as an array of everyStory.characters[THIS table storyOffset].index ?
          I suggest to call simply ThisTable.storyOffset. It is an insertionPoint (object) which can be your current target for further proccessing. (still using backward loop of cource).
          So there are 2 more question left:
          1. How to create a textFrame
          2. How to fit this frame to current table size
          both depends on version of InDesign in use so I break here...
          Jarek
