9 Replies Latest reply on Nov 21, 2016 3:34 AM by moluapple
    draw rectangle arround a textRange or textSelection?
    levi23 Level 1
      Hello such.
      My question is simple. it is possible to get bounds of a textRange or TextSelection?
      Draw the rectangle already know how to do it, but do not know how I can get the coordinates to draw it. I think it's not possible.
      I'm wrong?
      I would greatly appreciate your help.
      a greeting
        • 1. Re: draw rectangle arround a textRange or textSelection?
          o-marat Level 3
          Hello, levi23!
          You want to get this bounds?
          Most likely you're right – through script no possible...textRangeTextSelection-01.png
          • 2. Re: draw rectangle arround a textRange or textSelection?
            levi23 Level 1
            feared. And a part of the text (not the entire text) even if not selected?
            Thank you.
            a greeting
            • 3. Re: draw rectangle arround a textRange or textSelection?
              o-marat Level 3
              The only thing that came to my mind:
              • find the numbers of the needed characters
              • copy the text frame
              • make it curves
              • find the desired paths by numbers
              • edit (e.g., add a frame around)
              • remove the copy
              • 4. Re: draw rectangle arround a textRange or textSelection?
                Silly-V Adobe Community Professional
                Good approach. Extra help when doing this kind of operation is to color the desired text some key color so that when the text is converted to curves, you can easily isolate the bounds of that text by using a fill color as the 'filter' in the code.
                • 5. Re: draw rectangle arround a textRange or textSelection?
                  CarlosCanto Adobe Community Professional & MVP
                  here's one way of doing it.
                  // drawRectangleAroundSelectedTextRange
                  // CarlosCanto
                  // https://forums.adobe.com/thread/2232244
                  function main () {
                      var idoc = app.activeDocument;
                      var sel = idoc.selection;
                      if (sel.typename == "TextRange") {
                          var iframe = sel.parent.textFrames[0];
                          var dup = iframe.duplicate();
                          var range = sel;
                          var rl = range.length;
                          var story = range.story.textRange.contents;
                          var sl = story.length;
                          var rangeStart = range.characterOffset-1; // 1 based
                          var rangeEnd = rangeStart+rl;
                          var chars = range.story.textRange.characters;
                          // remove from end of selected range to end of story
                          if (rangeEnd < sl) {
                              var delrange = chars[rangeEnd];
                              delrange.length = sl-(rangeEnd);
                              delrange.remove();
                          // remove from beginning of story to beginning of selected range
                          var dup2 = iframe.duplicate();
                        delrange = dup2.characters[0];
                        delrange.length = rangeStart;
                        delrange.remove();
                        // remove range itself to get the first part of the text frame
                        range.remove();
                        dup2.position = [iframe.position[0]+iframe.width, iframe.position[1]];
                        // make outlines and draw rectangle
                        var igroup = dup2.createOutline();
                        var margins = 1.5;
                        var ipath = idoc.pathItems.rectangle(igroup.top+margins, igroup.left-margins, igroup.width+margins*2, igroup.height+margins*2);
                        ipath.filled = false;
                        ipath.stroked = true;
                        ipath.move(dup, ElementPlacement.PLACEBEFORE);
                        // remove duplicates
                        igroup.remove();
                        iframe.remove();
                      else {
                          alert('Select a Text Range and try again');
                  main ();
                  • 6. Re: draw rectangle arround a textRange or textSelection?
                    levi23 Level 1
                    Woow much appreciate your response. The problem is that it only works on point text in a single line. Could adapt to mutilinea texts? (Point text and paragraph texts)?
                    Thank you very much again.
                    Apologized other question if it is not too much to ask. You could take a look at this post?
                    force redraw() script
                    Maybe your great knowledge get me out of doubt.
                    I just want to know if when making a TextRange by script. This can be used manually in the program in some way (removing it with the delete key for example)
                    Thank you very much
                    • 7. Re: draw rectangle arround a textRange or textSelection?
                      you'll have to split your multiline text into single lines first, search the forum, there should be scripts dealing with that, there's one made by Wundes.
                      check these threads as well
                      Re: Split TextFrame Lines
                      Re: How to divide all textFrames in one-character-per-textFrame?
                      about the other question, I haven't found an answer either.
                      • 8. Re: draw rectangle arround a textRange or textSelection?
                        o-marat Level 3
                        As another way - the code is written according to the algorithm, which I quoted earlier:
                         * ai.jsx (c)MaratShagiev m_js@bk.ru 08.11.2016
                         * makes frame around TextRange.textSelection
                        //@target illustrator
                        (function addRectByTxtSel () {
                          var d        = activeDocument,
                              fr       = d.textFrames[0],
                              re       = /\s/gmi,
                              marg     = 2,
                              col      = new CMYKColor (),
                              selStart = fr.textSelection[0].characterOffset - 1, // first selected char
                              selLen   = fr.textSelection[0].length, // text selection lenght
                              selEnd   = selLen + selStart - 1, // last selected char
                              fixSelLen, selSpaces,
                              past, fixPastLen, pastSpaces,
                              frCurv, gr, rect,
                              selItems = [];
                          col.magenta = 100;
                          col.yellow  = 100;
                          fixSelLen = selLen;
                          selSpaces = fr.textSelection[0].contents.match (re);
                          if (selSpaces) {
                            fixSelLen = selLen - selSpaces.length;
                          past        = fr.textRange.characters[selEnd + 1];
                          past.length = fr.contents.length - selEnd - 1;
                          fixPastLen = past.length;
                          pastSpaces = past.contents.match (re);
                          if (pastSpaces) {
                            fixPastLen = past.length - pastSpaces.length;
                          frCurv          = (fr.duplicate ()).createOutline ();
                          for (var i = fixPastLen; i < fixPastLen + fixSelLen; i++) {
                            var obj1 = frCurv.pageItems[i];
                            selItems.push (obj1);
                          gr = d.activeLayer.groupItems.add ();
                          for (var j = 0; j < selItems.length; j++) {
                            var obj2 = selItems[j];
                            obj2.move (gr, ElementPlacement.INSIDE);
                          rect = d.activeLayer.pathItems.rectangle (
                            gr.position[1] + marg, gr.position[0] - marg, gr.width + marg * 2, gr.height + marg * 2);
                          rect.filled      = false;
                          rect.strokeColor = col;
                          gr.remove ();
                          frCurv.remove ();
                        If hyphenation  in Illustrator palette is enabled, it is not working correctly (cause the hyphens are not taken in the calculation). But I think it can be fix.
                        • 9. Re: draw rectangle arround a textRange or textSelection?
                          moluapple Level 4
                          Hello, also another way(working with multiline & hyphenation). Code based on Carlos
                          function main() {
                                  dup.selected = false;
                                  var range = sel;
                                  // log color
                                  var col = range.characterAttributes.fillColor;
                                  //set fill color to blank
                                  range.story.textRange.characterAttributes.fillColor = new NoColor();
                                  //set fill color again
                                  range.characterAttributes.fillColor = col;
                                  //apply outline effect
                                  var effectStr = '<LiveEffect name="Adobe Outline Type">' + '<Dict data=""/>' + '</LiveEffect>';
                                  iframe.applyEffect(effectStr);
                                  iframe.selected = true;
                                  //expand appearance
                                  app.executeMenuCommand('expandStyle');
                                  var igroup = app.selection[0];
                                  var margins = 1.5;
                                  var ipath = idoc.pathItems.rectangle(igroup.top + margins, igroup.left - margins, igroup.width + margins * 2, igroup.height + margins * 2);
                                  igroup.remove();
                              } else {
                          main();
