3 Replies Latest reply on Mar 15, 2012 10:39 PM by Patel Bharat
    Retrieving column number in the datagrid
    nash99
      Hi ,
      I was trying to retrieve the column number in the datagrid , when we click on the header of the datagrid(on the corresponding column).
      are there any events to retrieve the column number of the column selected .
      I tried using the headerRelease="ClickEvent(event); in the
      <mx:DataGrid id="dg"
      width="100%" height="50" rowHeight="50" editable="true"
      headerRelease="ClickEvent(event);">
      I was able to get the column number using this but
      when the event is called the control is sorting the datagrid column .
      I dont want the datagrid column to be sorted (I tried giving sortable = false , it does'nt help).
      Is there any other way , I could get the data grid column number , when the data grid column header is clicked.
      thanks
        • 1. Re: Retrieving column number in the datagrid
          Murshed1992
          Since it is going to sort when you click on the header, you can redirect the sort function:
          sortCompareFunction="myFuncName"
          • 2. Re: Retrieving column number in the datagrid
            jfb00 Level 3
            Why do you need the column number?
            What are you trying to do?
            • 3. Re: Retrieving column number in the datagrid
              Patel Bharat Level 2
              Hi
              Try below code. On column header click, will get column number / index:
              <mx:Script>
                  <![CDATA[
                            import mx.events.DataGridEvent;
                      import mx.events.ListEvent;
                      private function itemClickEvent(event:DataGridEvent):void {
                          clickColumn.text=String(event.columnIndex);
                          eventType.text=event.type;
                  </mx:Script>
                  <mx:DataGrid id="myGrid" width="350" height="150"
                          headerRelease="itemClickEvent(event)">
                      <mx:ArrayCollection>
                          <mx:Object Artist="Pavement" Price="11.99"
                              Album="Slanted and Enchanted" />
                          <mx:Object Artist="Pavement" Album="Brighten the Corners"
                              Price="11.99" />
                      </mx:ArrayCollection>
                  </mx:DataGrid>
                  <mx:Form>
                      <mx:FormItem label="Column Index:">
                          <mx:Label id="clickColumn"/>
                      </mx:FormItem>
                      <mx:FormItem label="Type:">
                          <mx:Label id="eventType"/>
                      </mx:FormItem>
                  </mx:Form>
              Enjoy RIA ..
