10 Replies Latest reply on Nov 7, 2016 3:30 PM by tokuredit
    How to copy the name of the folder and paste as text in Photoshop
    tokuredit Level 1
      I have about 200 image files of various sizes separated by folders, each folder represents a different customer. I need a text layer in each image that matches the name of each folder. It would be like this:
      • 1 Select Folder
      • 2 Copy the folder name
      • 3 Open the image
      • 4 Paste into a text layer. "Adding text in the image"
      I found this script, it's almost all I need: Only a change: Change the file name to the folder name. Thank you.
      // add document name in text layer;
      #target photoshop
      if (app.documents.length > 0) {
      var myDocument = app.activeDocument;
      var originalUnits = app.preferences.rulerUnits;
      app.preferences.rulerUnits = Units.PIXELS;
      // getting the name;
      var docName = myDocument.name;
      //var basename = docName.match(/(.*)\.[^\.]+$/)[1];
      //getting the location;
      //var docPath = myDocument.path;
      // make the layer;
      var myLayerRef = myDocument.artLayers.add();
      myLayerRef.kind = LayerKind.TEXT;
      myLayerRef.name = "text";
      var myTextRef = myLayerRef.textItem;
      myTextRef.size = 12;
      myTextRef.font = "Arial";
      myTextRef.justification = Justification.RIGHT;
      //Set text colour in RGB values
      var newColor = new SolidColor();
      newColor.rgb.red = 192;
      newColor.rgb.green = 44;
      newColor.rgb.blue = 44;
      myTextRef.color = newColor;
      // Set the position of the text - percentages from left first, then from top.
      myTextRef.position = new Array( myDocument.width -670, myDocument.height -1640);
      myLayerRef.blendMode = BlendMode.NORMAL;
      myLayerRef.opacity = 100;
      myTextRef.contents = docName;
      app.preferences.rulerUnits = originalUnits;
      //that’s it; thanks to xbytor;
