Rack222,
After three hours, I finally have this working. In my case, I
was moving to a new computer, and Office was installed, but not
activated when I installed Robohelp Technical Suite. So, based on
all the suggestions in other posts here is what I did. Now, I have
no idea why what I did managed to make it work, or if you need all
the steps. But nevertheless, here they are:
-Uninistall Robohelp (or technical suite) reboot computer.
-Go to documents and settings\yourUserName\Application
Data\Microsoft\Office\Word\Startup and remove the robohook.wll (if
it exists)
-Reinstall Technical Suite.
-Open Word. Go to Help>>About>>Disabled Items and
make sure the PDF creator is not disabled.
Now I opened the Clownfish Project in Robohelp.
Open Tools>>Options.
When the window opens make sure these settings are correct:
File Associations: .xml, .js
HTML Editors:
robohelp WYSIWYG <Internal> Default = Yes
Notepad
Word 2003
Auto Select Editor (Checked)
Then try to generate printed documentation.
If that doesn't work, then change the default editor to Word
2003.
-Open a few of the Clownfish project htm files.
-Robohelp will flash a message and open the document in
word.
-Reset the default editor back to Robohelp
-Try to generate printed documentation.
If that doesn't work:
-then copy winword.exe to the c:\ (root directory)
-Go back to the Tools>>Options window
-Add a second Microsoft Word HTML editor and point this
entry to the c:\winword.exe copy.
-Set this as the default editor
-Check the Use Default Editor
-Save and Close the window.
Now, try to open one of the html project files.
-Robohelp will flash a message that these need to be edited
in a third party editor.
- Then a "windows installer" program opens for the new
instance of word and installs word for the current user and path.
- then the project page opens in word.
- You should be able to import Word documents into your
project.
Now, go back to the Tools>Options window.
-Set Robohelp as the default editor
-delete the second Microsoft Word entry
-Check the Auto-Select Editor
-Save and close the window.
My printed documentation now works.
I think it was the word installation that was somehow not
associated with my user ID on my computer that caused the problem.
Somehow getting the mini-installer to run seems to do the trick.
Hope this helps.
Marilyn
