Crash plugin in the new version Adobe Audition CC 2017.
Сообщение отредактировано: Артём Туманов
I like to find solutions in difficult situations).
Run the program in compatibility mode with Windows 8 and try it on.
Don't mention it.
See the FAQ Audition Crashed. Now what?
Happens to me also
Don't mention it.
THANK YOU
repairer's solution isn't one, I'm afraid.
The answer is quite simple - you can't run a 32-bit plugin (as Audition 3 uses) in the present 64-bit-only version, unless you use something like jbridge. So you either get a copy of that, or update your plugin for a newer 64-bit version of it.
repairer's solution worked
