6 Replies Latest reply on Nov 7, 2016 5:00 AM by Obi-wan Kenobi
    Can't change Measurement Unit
    Gregorio Pellegrino
      I'm developing a script. I would like to manage dimensions in millimeters; so I added at the top of the script:
      app.scriptPreferences.measurementUnit = MeasurementUnits.MILLIMETERS;
      But then I try to resize the page, and the dimensions are managed as points:
      app.activeWindow.activePage.resize(CoordinateSpaces.INNER_COORDINATES, AnchorPoint.CENTER_ANCHOR, ResizeMethods.REPLACING_CURRENT_DIMENSIONS_WITH, [240, 100]);
      Can you help me to understand where I'm wrong?
      Gregorio
        • 1. Re: Can't change Measurement Unit
          Obi-wan Kenobi Level 5
          Personally, about MeasurementsUnits:
          // ----------- Script beginning -----------
          var savedHorizontalMeasurementUnits = myDoc.viewPreferences.horizontalMeasurementUnits;
          var savedVerticalMeasurementUnits = myDoc.viewPreferences.verticalMeasurementUnits;
          myDoc.viewPreferences.horizontalMeasurementUnits = MeasurementUnits.MILLIMETERS;
          myDoc.viewPreferences.verticalMeasurementUnits = MeasurementUnits.MILLIMETERS;
          // ----------- Script end -----------
          myDoc.viewPreferences.horizontalMeasurementUnits = savedHorizontalMeasurementUnits;
          myDoc.viewPreferences.verticalMeasurementUnits = savedVerticalMeasurementUnits;
          • 2. Re: Can't change Measurement Unit
            Gregorio Pellegrino Level 1
            It doesn't work in my environment... Can't understand!
            Gregorio
            • 3. Re: Can't change Measurement Unit
              Hi Gregorio,
              it is not working in any environment.
              all x and y values for resize() are accepted as points only.
              The same with reframe() and transform().
              Recommended:
              Indiscripts :: Coordinate Spaces & Transformations in InDesign — Chap.1-3
              Indiscripts :: Coordinate Spaces & Transformations in InDesign — Chap.4 (Draft)
              There is UnitValue you could use to do the necessary conversions.
              var convertedValue = UnitValue(100,MeasurementUnits.MILLIMETERS).as(MeasurementUnits.POINTS);
              Regards,
              Uwe
              • 4. Re: Can't change Measurement Unit
                Hi Uwe,
                Right!
                var W = UnitValue("240mm").as('pt'); ;
                var L = UnitValue("100mm").as('pt');
                app.activeWindow.activePage.resize(CoordinateSpaces.INNER_COORDINATES, AnchorPoint.CENTER_ANCHOR, ResizeMethods.REPLACING_CURRENT_DIMENSIONS_WITH, [W,L]);
                • 5. Re: Can't change Measurement Unit
                  Hi Obi-wan,
                  in this case changing the viewPreferences is not necessary.
                      resize
                          [W,L]
                  Regards,
                  Uwe
                  • 6. Re: Can't change Measurement Unit
                    You're right!
                    Just a habit of systematical work in a "millimeters" context!
