11 Replies Latest reply on Nov 10, 2016 7:50 AM by Laubender
    PDF options
    jakec42735283 Level 1
      Hi everyone,
      Is it possible to set a PDF to show bookmarks through scripting in InDesign (as in after exporting in the script, can you access the PDF DOM?)? Or does this need to be done directly in Acrobat?
      I'd want to do the same as:  properties>navigation tab>bookmarks panel and page
        • 1. Re: PDF options
          Trevorׅ Adobe Community Professional
          Hi Jake,
          As far as I know you can't do it from the InDesign side so you would either have to send the pdf to Acrobat with some more vbs and have acrobat set the view options or try hack the raw binary file pdf file.
          In other words see what acrobat does to the binary file and see if you can emulate that.
          It might be quite easy or it might be not practical.
          Regards
          Trevor
          • 2. Re: PDF options
            Thanks Trevor, I'll do some experiments
            • 3. Re: PDF options
              Hi
              The hack method could be quite tough but the vbs looks simple.
              See How do I create PDF with JAVASCRIPT using VBS ? (JavaScript)
              The js method from the acrobat DOM is this.pane = 'Bookmark'; (or this.pane = 'B')
              Might be bookmark with a small b, I can't rembember
              The script they give there is
              Dim AcroApp
              Set AcroApp = CreateObject("AcroExch.App")
              AcroApp.Show()
              Set objPDDocNew = CreateObject("AcroExch.PDDoc")
              If objPDDocNew.Create() = False Then
                MsgBox "Could not create new file"
              End If
              Set objPDDoc = CreateObject("AcroExch.PDDoc")
              If objPDDoc.Open("C:\tmp\Untitled.pdf") = False Then
                MsgBox "Could not open existing file"
                Return
              End If
              lngPages = objPDDoc.GetNumPages
              'MsgBox "Existing doc page num " & lngPages
              'Add pages to new file
              If objPDDocNew.InsertPages(-1, objPDDoc, 0, lngPages, True) = False Then
                MsgBox "Could not insert pages"
              End If
              Dim jso
              Set jso = objPDDocNew.GetJSObject
              jso.app.alert(jso.author)
              jso.addScript "DocScript", "function f() {app.alert('doc alert')} f();"
              Set jso = Nothing
              If objPDDocNew.Save(1, "C:\tmp\tmp.pdf") = False Then
                MsgBox "Could not save"
              End If
              objPDDocNew.Close()
              Set objPDDocNew = Nothing
              objPDDoc.Close()
              Set objPDDoc = Nothing
              AcroApp.Hide()
              AcroApp.Exit()
              Set AcroApp = Nothing
              So I would guess if your created document variable is objDoc then in vbs one would do Set objDoc.Pane = "Bookmark"
              HTH
              Trevor
              • 5. Re: PDF options
                Hi Trevor,
                Thanks for the link
                I've made an action in Acrobat which does this, would it be easier to run the action using vb/javascript?
                • 6. Re: PDF options
                  I would guess vbs but I would advise asking on the acrobat scripting thread above.
                  Gilad (Try67) knows a lot more about acrobat workflow than me
                  • 7. Re: PDF options
                    Hi Jake,
                    the following is not meant as a "solution", but a possible way one could explore.
                    And yes, it can be done with some ExtendScript, InDesign's printing to PostScript feature and distilling to PDF by using Acrobat Distiller. E.g. by writing to a Distiller hotfolder. Not by using export to PDF. But since you are using bookmarks created with InDesign and exported to PDF, this may not be reliable.
                    I'm speaking of pdfmark annotations that can be placed with one or several generic EPS files to InDesign pages.
                    But the interpretation of this kind of annotations for PDFs can only made by Acrobat Distiller when creating a PDF out of PostScript or EPS.
                    The basic code of the EPS file is very simple, pure text that can be written to a file with suffix ".eps".
                    The EPS file will be later placed by using ExtendScript's method place() . Simple as that.
                    Code for a minimal EPSF header:
                    %!PS-Adobe-3.0 EPSF-3.0
                    %%BoundingBox: 0 0 72 72
                    %%EndProlog
                    Code for a minimal footer:
                    %%EOF
                    Between header and footer can go the pdfmark annotation stuff. See here what's possible:
                    http://www.adobe.com/content/dam/Adobe/en/devnet/acrobat/pdfs/pdfmark_reference.pdf
                    Especially:
                    Page 29:
                    Document open options (DOCVIEW)
                    A code like the one below inside an EPS will be translated by Distiller to include an instruction for Adobe Reader or Acrobat Pro to open the PDF with bookmarks showing:
                    [ /PageMode /UseOutlines /DOCVIEW pdfmark
                    If your bookmarks are simple ones, e.g. from a TOC with an InDesign document, you could also extract the necessary information for "Title" and "Pagenumber" for every bookmark by using the ExtendScript DOM and build your own bookmarks with pdfmark instructions. See Page 26: Bookmarks (OUT)
                    It's a shame that InDesign's PDF Export will not evaluate pdfmark instructions that come with placed EPS files.
                    Regards,
                    Uwe
                    2 people found this helpful
                    • 8. Re: PDF options
                      Very interesting, Uwe, be hear if it can be got to work
                      • 9. Re: PDF options
                        Hi Trevor,
                        forgot a line of PostScript, that should be included before doing the pdfmark annotations in the EPS code.
                        That line will disable the pdfmarks when printed on a PostScript printer, because pdfmark code will throw an error with the PostScript RIP:
                        /pdfmark where {pop} {userdict /pdfmark /cleartomark load put} ifelse
                        Regards,
                        Uwe
                        • 10. Re: PDF options
                          Thanks for all your help, I'll have a look into this and if I find a solution I'll be sure to post it here
                          • 11. Re: PDF options
                            Hi Jake,
                            if you want to explore the pdfmark route, see the following ExtendScript script by Muppet Mark that is distilling a PostScript file with Acrobat Distiller using some parameters:
                            Re: how to run system command
                            You could also do a "Watched Folder" with Distiller where you move a PostScript file to.
                            Used together with a hotfolder from Acrobat Pro where you can run a preflight process automatically.
                            ( That's also a note to myself :-) )
                            Regards,
                            Uwe
