6 Replies Latest reply on Nov 8, 2016 5:06 AM by brookeb0927
    Javascript calculations and Radio button values
    brookeb0927
      I have a couple questions regarding how to create calculations on a 150 question quiz using radio buttons that I have created.
      Each question has 3 choices. "yes" "No" or "?".  Each question is labeled as its coresponding number  (1,2,3,4,5, etc.) and the radio button choices are currently labeled as "Yes", "No, or "?".
      I need to assign a "1" to the correct answer and a "0" to the incorrect ones for each question (sidenote - a few questions have 2 acceptable answers, so two choice's would need to be labeled "1" and in all other instances there will be assigned values of "1", "0", and "0" <---does doing this then allow the user to click more than one button? I only want them to be able to choose a single answer for each qeustion.)
      Do I need to go back and relabel all 150 x 3 radio button choices to numbers to act as export values?
      Finally, Ill need to create a caculation based on the choices selected. Can I do this using the simple calculation function in a text field if I assign the values like I previoiusly mentioned? OR should I be using some sort of simplified or custom javascript in this instance? Apologies for the longest question ever. I am so stuck and would greatly appreciate any help at all.
        • 1. Re: Javascript calculations and Radio button values
          George_Johnson MVP & Adobe Community Professional
          It would probably be best if you changed the export values of each radio button to a number. It's OK for what you're doing if more than one in the group share the same export value. It becomes a problem if you want to programmatically set the field values or import form data.
          If you do this and you have field names like "radio1", "radio2", ..."radio150", you can use a relatively simple JavaScript to perform the calculation. The other options will be a lot more cumbersome with that many fields involved. The script could be something like:
          // Custom calculation script
          (function () {
              // Initialize variables
              var i, val, sum = 0;
              // Loop through the radio buttons and add numeric value of selected button to sum
              for (var i = 1; i <= 150; i += 1) {
                  val = getField("radio" + i).value;
                  if (val !== "Off") {
                      sum += +val;
              // Set this field's value to the sum
              event.value = sum;
          You'd replace "radio" in the script with whatever your field name prefix is.
          • 2. Re: Javascript calculations and Radio button values
            brookeb0927 Level 1
            Good Morning George_Johnson,
            Thank you very much for the information! I will change the radio button choices to numerical values!
            I currently have the radio button field names set to numbers; 1,2,3,4...150. Do I need to name them something else for this to work? You mentioned a "field name prefix"
            Also, I should have mentioned in my first post that this 150 question test is going to be scored in 5 categories. So I will need to create 5 text fields, each coresponding to 30 of the 150 questions, to score this quiz based on the categories.
            The questions which pertain to each category are placed in a numerical pattern but not consecutive (so as not to have the test taker realize the scheme). For example - 1,6,11,16,21,26,31,36 in category "A" and for category "B" - 2,7,12,17,22,27,32,37 category "C" - 3,8,13,18,23,28. I wasn't sure if this will complicate/change the JavaScript text needed. It looks like the example you sent me would only work for scoring this 1 through 150 (which is understandable based on the information, or lack there of, that I gave in my original post, sorry .)
            Finally, Will I be entering the javascript into the Custom calculation field or the simplified field?
            Thank you again this forum is a life saver for a beginner like myself.
            Brooke
            • 3. Re: Javascript calculations and Radio button values
              JR_Boulay Adobe Community Professional
              Hi.
              Assuming that your field are named (the dot really matters):
              radio.1
              radio.2
              radio.3
              etc.
              You just have to use the built-in Acrobat's calculation and pick the parent field only. As shown on the screengrab.
              See this demo PDF file: Shared Files - Acrobat.com
              • 4. Re: Javascript calculations and Radio button values
                brookeb0927 Level 1
                Thank you. I am just currently using that feature and it seems to be working, YAY! However, I did NOT change my feild names, they are still simply just "1", "2", "3"....will I run into problems if I keep them this way?
                • 5. Re: Javascript calculations and Radio button values
                  You must use at least one dot in field names to create a "virtual" parent field.
