1 Reply Latest reply on Dec 3, 2008 1:36 PM by ericbelair
    WebService using a bindable hostname - doesn't work
    Abobo
      I have the following code:
      [Bindable]
      private var myServerHostPort:String = "af arf";
      <!--wsdl="{myServerHostPort}/channel.asmx?wsdl"-->
      <!--wsdl=" http://localhost/mmo/channel.asmx?wsdl"-->
      <!--wsdl="@ContextRoot()/mmo/channel.asmx?wsdl"-->
      <mx:WebService
      id="channelList"
      concurrency="single"
      wsdl="{myServerHostPort}/mmo/channel.asmx?wsdl"
      fault="faultHandler(event)"
      makeObjectsBindable="true">
      <mx:operation
      name="GetChannelList"
      result="resultChannelListHandler(event)">
      <mx:request xmlns="">
      <transmitterAddress>{wsTransmitterAddress}</transmitterAddress>
      <channelFolder>{wsChannelFolder}</channelFolder>
      </mx:request>
      </mx:operation>
      </mx:WebService>
      My application is defined as:
      <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml"
      layout="absolute"
      creationComplete="initializeApplication()"
      width="1100" height="800"
      In the debugger, I can see the initialApplication() function being called.
      private function initializeApplication():void
      trace('initializeApplication: myServerHostPort:'+myServerHostPort);
      myServerHostPort = NetworkUtil.getServerURL();
      In the debugger, I see the myServerHostPort = 'af arf', then it is
      changed to something correct: http://localhost
      After I hit F8, I get this fault reported:
      faultDetail="Unable to load WSDL. If currently online, please verify
      the URI and/or format of the WSDL (af arf/mmo/afaria/channel.asmx?wsdl)
      You see here it is still using the original value instead of the one
      set in the initializeApplication() function.
      So a few questions:
      1. Why is it even calling this WebService automatically? I only want
      to call it when "I" call it. For some reason it is being called
      during the initialization process and I don't want it to.
      2. Why is it using this old value? If it is a [Bindable] variable it
      should be using that.
      3. If someone can't offer a way to fix this, can you suggest
      alternatives.
      I have tried making the WebService calls via ActionScript myself to
      bypass the issue, but the loadWSDL() never seems to complete and there
      are no errors thrown.
      public function initWebService():void
      CursorManager.setBusyCursor();
      WS = new mx.rpc.soap.WebService();
      //location of the Web Service Description
      WS.wsdl = myServerHostPort+"/channel.asmx?wsdl";
      WS.endpointURI = myServerHostPort+"/channel.asmx";
      //GetChannelList is the WebService method we want to use
      //and we want the results returned in the e4x XML format
      WS.useProxy=false;
      WS.requestTimeout=2;
      WS.destination = "GetChannelList";
      //specify the function that will handle the results
      //returned by the operation
      WS.GetChannelList.addEventListener("result", resultChannelListHandler);
      //specify the method that will handle any faults
      WS.GetChannelList.addEventListener("fault", faultHandler);
      //specify the method that will handle the
      //the event of loading the WSDL
      //once the WSDL is loaded we will call
      //our method in the function loadHandler
      WS.addEventListener("load", loadChannelListHandler);
      //Load the WSDL for this WebService
      WS.loadWSDL();
      }//end function useWebService
      private function loadChannelListHandler(e:LoadEvent):void
      CursorManager.removeBusyCursor();
      wsdlLoaded = true;
      ta.text = "wsdl loaded" + "\n\n";
      Thanks for any feedback.
      Dave
