Since update to 2017.0 every time when I select a earlier entered text within a indesign document, a turning beach ball appears, stalls for 10 secs, beach ball disappears. Happens every time I select a new text. I’m unable to work on documents in Indesign. Also happens when selecting other font.
Tried:
- remove all Indesign settings
- create fresh new document
… without result.
I saw a similar question on an earlier thread and the suggestion was to disable the Type Contextual Controls. Could you give it a try and then come back to let us know?
Edit: I found the thread: Type tool is very delayed in InDesign CC
Hello Barbinder,
This solved my problem. Thank you very much!
(Adobe support logged in remotely and concluded it was a Extensis Suitcase problem).
Many thanks.
I've been suffering through this issue for weeks and had tried everything -- including uninstalling and reinstalling the whole CC suite.
This was the only thing that worked, and it's such an easy fix!
Thank you!!
