I am trying to find and replace the words from .txt file to indesign contents. If i have repeated words in .txt file the indesign also did for 3 times. The below image illustrates much better. Sorry i am improving my english to convey the requirement better.
Script Tried:
myfndchange();
function myfndchange(){
var myFolder = File.openDialog("Select the TXT file to Proceed",isSupportedTXT,true);
if(myFolder!=null){FilePath=decodeURI(myFolder);}
if(myFolder==null){return;}
var datafile = new File(FilePath);
datafile.open('r') ;
while (!datafile.eof){
strLineIn = datafile.readln();
colorArray = strLineIn.split("\t");
var myColumn1=colorArray[0];
var myColumn2=colorArray[1];
var flag=0;
x=myColumn1.split(" ");
app.findTextPreferences = app.changeTextPreferences = null;
app.findChangeTextOptions.includeLockedLayersForFind = true;
app.findChangeTextOptions.includeLockedStoriesForFind = true;
app.findChangeTextOptions.includeHiddenLayers = false;
app.findChangeTextOptions.includeMasterPages = true;
app.findChangeTextOptions.includeFootnotes = true;
app.findChangeTextOptions.caseSensitive = false;
app.findChangeTextOptions.wholeWord = true;
mydoc=app.documents[0];
app.findTextPreferences = null; app.changeTextPreferences = null;
app.findTextPreferences.findWhat=myColumn1;
var myfound=mydoc.findText();
for(i=0;i<myfound.length;i++){
if(myfound.words.length===x.length){
app.changeTextPreferences.changeTo = myColumn1+"/"+myColumn2;
myfound.changeText()
function isSupportedTXT(file) {
try {
if (file instanceof Folder)
return true;
else
return file.name.match(/\.txt$/i) != null;
} catch (e) {
alert("Error in isSupported method: " + e);
K
I suggest
(keeping idea read - split - unique - change):
...Array.prototype.unique = function() {
var res = [], k, i, loop;
loop: for (k = 0; k < this.length; k++) {
for (i = 0; i < res.length; i++)
if (this
== res) continue loop; res.push(this
return res;
var
myDoc =app.documents[0],
myFile = File.openDialog("Select a TXT file to proceed","*.txt",false),
mySource = [], cLine, cCol1, cCol2;
if (!myFile)
Hello Experts,
Any quick suggestions is appreciated. I hope somebody help to sort out the issue.
Regards,
Karthi
Hi Karthi,
I think I've understood what you mean!!
Try this:
myfndchange();
var flag=0;
app.findGrepPreferences = app.findGrepPreferences = null;
app.findGrepPreferences.findWhat = myColumn1 + "(?!/)";
var myfound=mydoc.findGrep();
app.changeGrepPreferences.changeTo = myColumn1+"/"+myColumn2;
myfound.changeGrep()
try {
return true;
else
} catch (e) {
I suggest to read entire txt file --> split it by lines --> make an array unique --> use it as a base for find...replace procedure
Jarek
This version seems to be faster!
myDoc = app.documents[0];
myFindchange();
function myFindchange () {
if (myFolder != null) FilePath=decodeURI(myFolder);
if (myFolder == null) return;
datafile.open();
var myWords = datafile.read();
myWords = myWords.split("\n");
W = myWords.length;
datafile.close();
while (W--) {
myWord = myWords
.split("\t"); var myWord0 = myWord[0];
var myWord1 = myWord[1];
app.findGrepPreferences = app.changeGrepPreferences = null;
app.findGrepPreferences.findWhat = myWord0 + "(?!/)";
var myfound = myDoc.findGrep();
for(i = 0; i < myfound.length; i++){
app.changeGrepPreferences.changeTo = "$0/" + myWord1;
function isSupportedTXT (file) {
try {
if (file instanceof Folder) return true;
else return file.name.match(/\.txt$/i) != null;
catch (e) {
Hi Obi,
Thanks for the quick reply. I expected your answer after i posted You did that..
Thanks Jump_Over for your suggestions...
Thread 4..This version seems to be faster!.. NOT WORKING>> IT ALMOST RUNNING ENDLESS
Regards,
K
Hi Obi,
I am facing with the code as you provided in thread 2.
See the below screen shot:
Please see the red marked line. It should not be updated. Also the replaced things also wrong.
It can be eliminated in Text search instead of Grep. Because it have
K
Hello Obi,
Any suggestions please
I suggest
if (this
return res;
var
if (!myFile) exit();
with (app.findChangeTextOptions){
wholeWord = true;
myFile.open('r');
do
mySource.push(myFile.readln());
while (!myFile.eof);
myFile.close();
mySource = mySource.unique();
while (cLine = mySource.pop()) {
cCol1 = cLine.split("\t")[0];
cCol2 = cLine.split("\t")[1];
app.findTextPreferences.findWhat = cCol1;
app.changeTextPreferences.changeTo = cCol1 + "/" + cCol2;
myDoc.changeText();
Jarek
Hi Jarek,
Awesome.. it working as expected.. you are my time saver man.. for this reason i created a new thread..
FindGrep() and FindText() together
Thank you so much
Thanks Obi for the part of this thread.. your's suggestions also valuable and new learning for me
Regards,
K
Hello Jarek,
One small issue happened. See below:
The word "STARTING AT" used in "SALE STARTING AT", so it put the two words (10, 11) in "SALE STARTING AT"
Could you please suggest?
K
Karthi,
Would do you want?
SALE STARTING AT/10
SALE STARTING AT/10
STARTING AT/11
The devil is in the details - as always
I thinks it should go with Grep
alike:
if (this
return res;
var
with (app.findChangeGrepOptions){
//caseSensitive = false;
//wholeWord = true;
myFile.open('r');
do
app.findGrepPreferences.findWhat = "(?i)^" + cCol1 + "$";
app.changeGrepPreferences.changeTo = cCol1 + "/" + cCol2;
myDoc.changeGrep();
Jarek
Hi Jarek & Obi,
Sorry if i confused anything. Yes i need as you said in thread 12.
@Jarek: I avoid using Grep search because it does not have case sensitive option. i tried from my end and it is working fine...
@Obi: Thanks again for your effort
The below script is working for me
if (this
return res;
var
wholeWord = true;
myFile.open('r');
do
myFile.close();
var flag=0;
x=cCol1.split(" ");
var myfound=myDoc.findText(true);
xx=0;
for(j=0;j<x.length;j++){
xx=xx+myfound.words
.characters.length; }
if(myfound.words.length>1){xx=xx+myfound.words.length-1;}
if(xx===cCol1.length){
app.changeTextPreferences.changeTo = cCol1+"/"+cCol2;
try{myfound.changeText();}
catch(er){
if(flag==0){
alert(cCol1+"\n");
flag=1;
if(myfound.length==0){ alert(cCol1+"\n")}
K
Jarek,
I try to play the game with other text!
For that, First, I apply a condition, then I search on this condition!
My list is:
Obi-wan | 1 |
Master Obi-wan | 2 |
Obi-wan The Jedi | 3 |
Obi-wan Kenobi | 4 |
My text is:
I’m Obi-wan!
Master Obi-wan!
Obi-wan The Jedi!
Obi-wan Kenobi!
… and I would want to get this:
I’m Obi-wan/1!
Master Obi-wan/2!
Obi-wan The Jedi/3!
Obi-wan Kenobi/4!
But your modified script aborts before the second "while"! An idea? Thanks in advance!
if (this
return res;
var
myFile.open('r');
do
app.findGrepPreferences.findWhat = cCol1;
app.changeGrepPreferences.appliedConditions = ["OBW"];
myDoc.changeGrep();
app.findGrepPreferences.findWhat = "(?<!.)" + cCol1 + "(?!.)";
app.findGrepPreferences.appliedConditions = ["OBW"];
app.changeGrepPreferences.changeTo = "$0/" + cCol2;
app.changeGrepPreferences.appliedConditions = [];
myDoc.changeGrep();
At the end of 1st 'while' mySource become an empty array ==> method pop() decrease it by 1 returning last element
Jarek
Jarek,
I saw that but I don't find the way to reinitiate "mySource'!
OK!
if (this
return res;
var
myFile.open('r');
do
mySource1 = mySource.unique();
while (cLine = mySource1.pop()) {
myDoc.changeGrep();
mySource2 = mySource.unique();
while (cLine = mySource2.pop()) {
myDoc.changeGrep();
To finish, just need to insert the creation of the condition "OBW" and its deletion at the end!
Done! Thanks Jarek, your code is coo!
if (this
return res;
var
myDoc = app.documents[0],
myCondition = myDoc.conditions.add ({name: "OBW"}),
myFile.open('r');
do
app.changeGrepPreferences.appliedConditions = [myCondition];
myDoc.changeGrep();
app.findGrepPreferences.appliedConditions = [myCondition];
myDoc.changeGrep();
myCondition.remove();
Use "for" instead of while.
You mean that if I use a "for" loop, no need to reinitiate "mySource"?
right
Thanks!
if (this
return res;
var
mySource = [], cCol1, cCol2;
myFile.open('r');
do
for (var c = 0; c < mySource.length; c++ ) {
cCol1 = mySource
.split("\t")[0]; app.findGrepPreferences = app.changeGrepPreferences = null;
myDoc.changeGrep();
cCol1 = mySource
.split("\t")[0]; cCol2 = mySource
.split("\t")[1]; app.findGrepPreferences = app.changeGrepPreferences = null;
myDoc.changeGrep();
Need now to study well, understand and to be able to replicate all the niceties of your great code!
Thanks a lot for the learning!
Karthi,
You wasn't not clear at all!
If I understand now well, the right list you could have could be this one:
Obi-wan 1
Obi-wan 2
Obi-wan 3
Luke 4
Han 5
Luke 6
… and the result you would want would be this one:
Obi-wan/1/2/3
Luke/4/6
Obi-wan/1/2/3
Han/5
Obi-wan/1/2/3
Darth Fourth
Luke/4/6 Fifth
Obi-wan/1/2/3
Right? [it's just for me to understand!]
Tests:
