0 Replies Latest reply on Dec 1, 2008 10:39 PM by kelloogo
    Issues with order of loading for ResourceBundle
    kelloogo
      I am trying to load the resource bundle at runtime depending on the locale setting. I have attached the sample code for it. The issue I am facing is that the initial few resource bundles are getting loaded, but the last three eg. ptbr, zhcn and zhtw are not getting loaded. When I change the sequence and take them to the top, they are getting loaded but again not the last few ones. I found a post on the similar problem that I am facing at the following link
      http://code.awenmedia.com/node/33
      But there was not a clear solution mentioned. Is there any such issue logged with Flex SDK and what is the alternative I can use. I do not want to make separate swf file for each language. Does anyone have a solution for this?
