• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Using drive path either local or mapped is intermittent
Community Beginner ,
Nov 08, 2016 Nov 08, 2016
Howdy,
When calling Webhelp from a C++ application running on windows 7 using a drive path works sometimes and sometimes not.
When using a web server it works rock solid.
Here's the samples;
CString s_help_server = "file:///z:/webhelp/wlib9_2hlp.htm>Window"; //mapped drive file based intermittent
CString s_help_server = "c:/inetpub/wwwroot/webhelp/wlib9_2hlp.htm>Window"; //file based intermittent
CString s_help_server = "http://TANK_2005/webhelp/wlib9_2hlp.htm>Window"; //web based solid
CString s_help_server = "http://localhost/webhelp/wlib9_2hlp.htm>Window"; //web based solid local computer
We really would like it to work with a mapped drive solidly,
We updated to RH11 and also are using the CSH_API that came with that.
Appreciate any help or insights.
Jim
Views
657
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Beginner , Dec 05, 2016 Dec 05, 2016
Howdy again,
Your test application doesn't open the default browser but always IE. I suspect it's doing what the RoboHelp_CSH.cpp and RoboHelp_CSH.h files do and open the Internet Explorer web control.
We're not using those files/ C++ API anymore.
I got this from the Microsoft Site and it seems to work pretty well here to launch IE using the web control IWebBrowser2, tried ShellExecute and some other methods, but this works solid; https://msdn.microsoft.com/en-us/library/aa752127(v=vs.85).aspx
Votes
Translate
Translate
Community Expert ,
No solution for you, but does it misbehave if you use a UNC path instead of the mapped drive?
Votes
Translate
Translate
Report
Report
Unfortunately it does the same misbehavior with a UNC path.
CString s_help_server = "//TANK_2005/xfer/webhelp/wlib9_2hlp.htm>Window";
That was a good idea to try, appreciate the input...
Votes
Translate
Translate
Report
Report
Community Expert ,
I was thinking more like (hope this comes through):
CString s_help_server = "file://c/inetpub/wwwroot/webhelp/wlib9_2hlp.htm>Window";
Votes
Translate
Translate
Report
Report
TANK_2005 is another machine, xfer is a drive share and using this does the same misbehavior;
CString s_help_server = "file://TANK_2005/xfer/webhelp/wlib9_2hlp.htm>Window";
Using the local path, on first attempt it doesn't launch, on second attempt it hangs the application in hour glass / spinning circle mode a minute or so, then additional attempts never launch help, so that's different...
This is the same misbehavior, being intermittent...
CString s_help_server = "file://c:/inetpub/wwwroot/webhelp/wlib9_2hlp.htm>Window";
as is this;
CString s_help_server = "file:///c:/inetpub/wwwroot/webhelp/wlib9_2hlp.htm>Window";
Votes
Translate
Translate
Report
Report
Nov 10, 2016 Nov 10, 2016
Well, I'm 98.6% sure it's not the syntax, I've tried every UNC combination possible and all get the same results.
I do see a pattern now, when using a drive path when calling RH_ShowHelp;
---Fails on first attempt
---Works on Second attempt
---Fails on all additional attempts
I've been setting some stop points in RoboHelp_CSH.cpp.
I put a stopper on s_pAxWin->QueryControl(IID_IWebBrowser2, (LPVOID FAR*)&pBrowser); highlighted below. I see this pattern also;
---It hits there only once on first attempt
---Hits there 5 times on second attempt
---Then never gets back there on additional attempts.
When using a web server path it ;
---Hits there 5 times every-time and works every-time.
IWebBrowser2* GetBrowser()
IWebBrowser2 *pBrowser = NULL;
// If the caller already initialize COM, please comment out the next 5 lines.
if (!gbCoInited)
::CoInitialize(NULL);
gbCoInited=1;
if (!s_pAxWin)
AtlAxWinInit();
s_pAxWin = new CAxWindow;
RECT rect;
rect.left = rect.top = 0;
rect.bottom = rect.right = 0;
rect.right = 200;
rect.bottom = 200;
s_pAxWin->Create(::GetDesktopWindow(), &rect, NULL, WS_CHILD);
s_pAxWin->CreateControl(L"{8856F961-340A-11D0-A96B-00C04FD705A2}");
if (s_pAxWin)
return pBrowser;
Been trying to find out what is causing that, but no luck yet.
Votes
Translate
Translate
Report
Report
LEGEND ,
Nov 11, 2016 Nov 11, 2016
There aren't many developers here, so we might not be able to help with the code.
How do you launch the browser? There is a difference in how browsers handle local files and files over HTTP. For local files, you can't just parse additional parameters after the filename. That confuses the browser. And IE won't open at all: you'll just get an error.
If you exclude the >Window from the call, does it behave then?
Votes
Translate
Translate
Report
Report
Yes, tried with and without >Window many times.
We are using the Robohelp API for C++ supplied with Robohelp. The code below is from the supplied RoboHelp_CSH.cpp file.
Here's our simple code to call RoboHelp.
//CString s_help_server = "file:///z:/webhelp/wlib9_2hlp.htm>Window"; //file based intermittent
//CString s_help_server = "c:/inetpub/wwwroot/webhelp/wlib9_2hlp.htm>Window"; //file based intermittent
//CString s_help_server = "http://TANK_2005/webhelp/wlib9_2hlp.htm>Window"; //web based solid
//CString s_help_server = "http://localhost/webhelp/wlib9_2hlp.htm>Window"; //web based solid local computer
CString s_help_server = "z:/webhelp/wlib9_2hlp.htm "; //latest attempted file path
int d = RH_ShowHelp(pMainWnd->m_hWnd, s_help_server, HH_DISPLAY_INDEX, NULL);
The green lines with // starting them are comments. That last line is the call to Robohelp.
It doesn't make sense that the calling code is problematic but something in RoboHelp_CSH.cpp or RoboHelp_CSH.h files where RH_ShowHelp() is defined -or- ?
Using C++.NET and the API supplied it makes an Active X Microsoft Web control on the fly, here's what it looks like when it works
Votes
Translate
Translate
Report
Report
LEGEND ,
Nov 18, 2016 Nov 18, 2016
Did you try to attach a screen shot? It didn't come through. You can only add images through the web interface, not by replying email.
I don't know C++ and I don't know how the API works. Is it possible to open the URI in a browser? Does that give you the same results?
Votes
Translate
Translate
Report
Report
Nov 21, 2016 Nov 21, 2016
Here is the picture I tried to attach via email.  Notice how the API makes a browser control on the fly...
Votes
Translate
Translate
Report
Report
LEGEND ,
Nov 28, 2016 Nov 28, 2016
I'm not a programmer, so debugging browser controls goes over my head.
What happens if you open the help in a browser instead of letting the API handle it? Do you then get the same results? You can use my CSH tester to test the different scenario's: http://www.wvanweelden.eu/sites/default/files/attachments/webhelp_api_csharp.zip
Votes
Translate
Translate
Report
Report
Nov 29, 2016 Nov 29, 2016
Your testing tool works fine. I can bring up a file based URL in the browser every time with it, ie;
file:///y:/wlib9_2hlp.htm#<id=1902>>newwnd=false
file:///y:/wlib9_2hlp.htm#<id=2035>>newwnd=false
file:///y:/wlib9_2hlp.htm#<cmd=toc>>newwnd=false
file:///y:/wlib9_2hlp.htm#<cmd=idx>>newwnd=false
The code in the API folder in your zip file shows how to make the URL, the code behind the Generate CSH URL button.
Do you also have the code behind the Show Help button that launches IE? <file:///y:/wlib9_2hlp.htm#<cmd=toc>>newwnd=false>
Really appreciate your help...
Votes
Translate
Translate
Report
Report
LEGEND ,
Dec 02, 2016 Dec 02, 2016
I'm not sure if I still have the source code lying around. But in short, it just does a file open command on the generated URL. That opens the URL in the system's default browser.
Votes
Translate
Translate
Report
Report
LATEST
Howdy again,
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
