• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
1
Strange image distortion bug
New Here ,
Nov 08, 2016 Nov 08, 2016
I'm working with indesign cc 2017 and lately my images in indesign are acting strange (see picture below). If the picture is being moved it will change back to the original image. But after some time it changes back to the distort image. Anyone else have this problem? Thanks
Views
12.2K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Feb 25, 2017 Feb 25, 2017
When this happens, since it's a GPU bug, instead of quitting out of the GPU (in Preferences), you can just choose View > Preview on CPU. The shortcut is Shift-E, which toggles between GPU and CPU. I use this shortcut if I see a display anomaly to test if it's GPU related.
Votes
Translate
Translate
Adobe Employee ,
Nov 09, 2016 Nov 09, 2016
Hi Jesse
On which OS are you working? Win or Mac? And, also mention the version.
Regards
Anasuiya Gupta
Votes
Translate
Translate
Report
Report
New Here ,
Hi!
I'm working on Mac, version 2017.0, build 12.0.0.81
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Hi Jesse
Please answer the following questions:
1. Is it an iMac or a Macbook? Do you have GPU in InDesign enabled?
2. Is it with a specofic file or with every image? If with a specific file, then please email that as a package to anasgupt@adobe.com
3. Is the issue seen with only images or graphics or a particular format like eps, jpeg, pdf, etc?
Regards
Anasuiya Gupta
Votes
Translate
Translate
Report
Report
New Here ,
Nov 15, 2016 Nov 15, 2016
Hi Anasuiya,
I'm having the same issue with random images in documents distorting. So far I've only run into it with JPG files, but because it happens randomly I'm not able to test to see if it also happens with EPS, PDF, etc. Your question about having GPU enabled caught my eye. I've turned it off and found that it solved the issue on one of my documents. (I haven't tried the others yet.) Just for kicks, I'll give you the details of the issue I've been having in case it is different or helps someone else solve their problem.
Because I've just updated to CC 2017 recently, I'm still opening many files created in the previous version of CC. The image distortions are mainly happening in those files. I'm not sure if I can yet point to a time when they've definitely happened in a newly created document. However, I do know for sure that it has happened in multiple files with multiple images. I often work off of a server, but have tried re-saving the troublesome images locally to see if that solves the problem and it seems to make a difference initially and then the images eventually re-distort. An important note: when exporting to PDF or JPG for final output, the distortion doesn't show. The output version appears to be fine. (Which is good, but it makes designing very challenging!)
Specs:
iMac Retina, late 2014 model, running 10.10.5
CC 2017.0 Release, 12.0.0.81 Build, GPU enabled (usually)
Let me know if you have any questions.
Best,
Leslie
Votes
Translate
Translate
Report
Report
New Here ,
I'm also having this problem, it started immediately after updating to CC 2017.
I've noticed if you toggle the Display Performance between Typical and High Quality you can invoke the problem on some images. I have also noticed that some images that were having this issue no longer do. It's almost like the images needed to be re-rendered after the update.
I was working on a big 100 page document which after conversion had lots of redraw issues, now it seems to be much better. So I'm hopeful any new documents will render correctly from the start. Maybe Adobe can offer some advice on if images are being re-rendered after the update?
I have the GPU enabled and I'm using the following Mac:
OS 10.11.6
Adobe InDesign CC 2017.0 (12.0.0.81)
iMac (Retina 5K, 27-inch, Late 2014)
4 GHz Intel Core i7
32 GB 1600 MHz DDR3
AMD Radeon R9 M295X 4096 MB
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Hi Leslie and David
It seems that while GPU rendering is enabled in InDesign, the distortion of images is taking place in some heavy documents.
Is it possible for you to share such files with us in which you saw the issue at anasgupt@adobe.com. This is help us identify the cause for the problem and test it out with documents that already have this issue.
Regards
Anasuiya Gupta
Votes
Translate
Translate
Report
Report
Community Expert ,
I have seen this on my own computer and on at least a dozen classroom computers—so both Macs and Windows. One file that comes to mind is the Classroom in a Book lesson on color. It's a one-page document, and is not what I would call a "heavy" document.
I'll send it to you, Anasuiya.
Votes
Translate
Translate
Report
Report
Community Expert ,
Votes
Translate
Translate
Report
Report
Explorer ,
Jun 07, 2017 Jun 07, 2017
I'm having the same issue. Latest versions of everything.
The previews are fine on Typical Display, but as soon as I move to High Quality Display it's an issue.
It's particularly bad in a new ground up 12 page document I'm working on at the moment.
I often 'save as' to overwrite, I've re-saved images in photoshop also.
Please help. It's very hard to work with it like this.
Votes
Translate
Translate
Report
Report
New Here ,
Aug 28, 2017 Aug 28, 2017
I'm having this issue as well, for some time now actually. Retina iMac with AMD Radeon R9 M290X 2048 MB Switching to CPU Preview or resizing the image in question within it's box will correct this. Very annoying, would love a fix.
Votes
Translate
Translate
Report
Report
Participant ,
Feb 07, 2017 Feb 07, 2017
I've posted this elsewhere but might help someone:
Also experiencing the same issue as above - images sometimes randomly distort and get 'squished'. Export is fine though. Seemed to fix when right clicking the image and selecting High Quality Display.
Also you might find that if you go to view>display performance you might have 'Allow Object-Level Display Settings' ticked. This would
presumably override the global display settings making some images appear more pixelated than Guybrush Threepwood's todger.
For good measure I selected Clear Object-Level Display settings.
These are useful settings if you are working on a large document or a particularly huge image is slowing you down because you would be able to set that single image to low quality whilst keeping the rest high quality. However, there seems to be a bit of a bug (?) in CC where these settings are automatically switching and causing confusion. And really, I've seen low res images in my time but these look like 8-bit toilet scrapings.
Votes
Translate
Translate
Report
Report
New Here ,
Feb 24, 2017 Feb 24, 2017
Helpful post and entertaining. '8-bit toilet scrapings'!
Votes
Translate
Translate
Report
Report
Participant ,
Feb 27, 2017 Feb 27, 2017
Whilst my fix worked it seems that the GPU bug is the real problem so switching to CPU (Shift-E) as stated above is a faster solution. Adobe have sad they are fixing this.
Votes
Translate
Translate
Report
Report
Community Expert ,
Elizabeth, my work-around is to select the picture and tap the right arrow key followed by the left arrow key. That seems to work for me.
Votes
Translate
Translate
Report
Report
Enthusiast ,
Feb 26, 2017 Feb 26, 2017
I have this from time to time in very light documents. I just assumed it's because my OS is way out of date (or that I had been drinking without realizing it)! Figured it was a re-draw/GPU issue. Thanks!
Votes
Translate
Translate
Report
Report
Community Expert ,
Basically, it appears that GPU-Acceleration, a newer feature, is not ready for prime-time. Go to Preferences and switch it off altogether, and the problem will go away. InDesign will still operate acceptably quickly.
Mike Witherell
Votes
Translate
Translate
Report
Report
Community Beginner ,
Sep 08, 2017 Sep 08, 2017
I had the same issue, now it looks fine after switching off the GPU-Acceleration,
Thanks for the help!
Votes
Translate
Translate
Report
Report
Explorer ,
Sep 11, 2017 Sep 11, 2017
Same problem here, nothing more to add except that I'm also using an iMac (Retina 5K, 27-inch, Late 2014).
Votes
Translate
Translate
Report
Report
New Here ,
Go to preferences and un-check "GPU-Acceleration", it'll fix it until Adobe updates this feature to become more stable.
Votes
Translate
Translate
Report
Report
New Here ,
Nov 02, 2017 Nov 02, 2017
I have the same problem and often too with text boxes that appear to be a solid colour. If I nudge them up or down then they redraw. I'll try the GPU off.
Votes
Translate
Translate
Report
Report
Community Expert ,
Which version, Peggy Sue? Release 2018 has come out since this question about 2017.
Votes
Translate
Translate
Report
Report
New Here ,
I'm still using ID cc2017 - I'm waiting a bit before I upgrade.
iMac (Retina 5K, 27-inch, Late 2015)
The other problem I have had, is a slow redraw. So when I move a block of text, it moves, but the image of where it was remains. I'll see if I can replicate it and post an image in this thread.
Votes
Translate
Translate
Report
Report
New Here ,
Sep 10, 2018 Sep 10, 2018
LATEST
Oh my goodness. Hours lost and Adobe support helped me figure it out. I was using the cursor arrow on the right (grey) instead of on the left (black). Whoops!
[All caps "shouting" converted to proper case by moderator.]
Votes
Translate
Translate
Report
Report
