2 Replies Latest reply on Nov 10, 2016 12:54 AM by natrev
    Save all layer combinations of 2 folders and keep one layer outside of the folders always visible no matter what combination
    navamez95629364
      i need a script to save images in jpg by combining the layers of 2 folders and to keep one layer outside of those 2 folders always visible
      Folder1
      -martin
      -jean
      Folder2
      -julie
      -poline
      1 layer outside of the groups (must be used always for every combinations)
      Wished result :
      best jpg quality images saved in a folder as followed:
      Many thanks
        • 1. Re: Save all layer combinations of 2 folders and keep one layer outside of the folders always visible no matter what combination
          navamez95629364 Level 1
          I have that script but I have 2 problems with it :
          1/ it works only for 1 folder and i have 2
          2/ it doesnt rename the saved files by combining the name of the layers
          // Name: Export Layers Inside Selected Group.jsx
          // Description: Photoshop script that separately saves top level layers inside the selected group.
          // https://gist.github.com/joonaspaakko/01 ... ba0fb9a2a0
          #target photoshop
          try {
          var doc = app.activeDocument;
          var docName = doc.name.split('.')[0];
          catch (e) {
          alert( 'Open a document first...' );
          function init() {
          var savefiles;
          dlg.g.saveAs.minimumSize.width = 463;
          dlg.btns.minimumSize.height = 142;
          dlg.btns.save.onClick = function(){
          savefiles = true;
          dlg.close();
          return savefiles;
          dlg.show();
          if ( savefiles ){
          var getDestination = Folder.selectDialog( 'Select destination folder...', doc.saved ? doc.path : '' );
          var group = doc.activeLayer;
          var groupLength = group.layers.length;
          for( var i = 0 ; i < groupLength; i++ ){
          group.layers[i].visible = false;
          var layer = group.layers[ i ];
          var layerIndex = i+1;
          layer.visible = true;
          save.file( dlg, doc, getDestination, layerIndex );
          layer.visible = false;
          alert('Files Saved!');
          var save = {
          file: function( dlg, doc, getDestination, layerIndex ) {
          var saveOptions = {};
          var formats = ["psd", "pdf", "png", "jpg", "tiff"];
          for ( var i=0; i < formats.length; i++ ) {
          if ( dlg.g.saveAs[ formats[i] ].value ) {
          var fileformat = formats[i];
          var path = getDestination + "/" + fileformat;
          makeFolder( path );
          doc.saveAs( File( path + "/" + dlg.g.filename.filename.text + layerIndex ), save[fileformat](), true );
          psd: function() {
          var psd_saveOpts = new PhotoshopSaveOptions();
          psd_saveOpts.layers = true;
          psd_saveOpts.embedColorProfile = true;
          psd_saveOpts.annotations = true;
          psd_saveOpts.alphaChannels = true;
          return psd_saveOpts;
          pdf: function() {
          var presetName = '[High Quality Print]';
          var pdf_SaveOpts = new PDFSaveOptions();
          pdf_SaveOpts.pDFPreset = presetName;
          return pdf_SaveOpts;
          jpg: function() {
          var jpg_SaveOpts = new JPEGSaveOptions();
          jpg_SaveOpts.matte = MatteType.WHITE;
          jpg_SaveOpts.quality = 10;
          jpg_SaveOpts.formatOptions.STANDARDBASELINE;
          return jpg_SaveOpts;
          png: function() {
          var png_SaveOpts = new PNGSaveOptions();
          png_SaveOpts.compression = 9;
          png_SaveOpts.interlaced = false;
          return png_SaveOpts;
          tiff: function() {
          var tiff_SaveOpts = new TiffSaveOptions();
          tiff_SaveOpts.alphaChannels = true;
          tiff_SaveOpts.annotations = true;
          tiff_SaveOpts.imageCompression = TIFFEncoding.JPEG;
          tiff_SaveOpts.interleaveChannels = true;
          tiff_SaveOpts.jpegQuality = 10;
          tiff_SaveOpts.layers = true;
          tiff_SaveOpts.layerCompression = LayerCompression.ZIP;
          tiff_SaveOpts.transparency = true;
          return tiff_SaveOpts;
          // Prepare dialog...
          var dlg = new Window("dialog { \
          text: 'Export layers inside the selected group', \
          alignChildren:['left','center'], \
          orientation: 'row', \
          g: Group { \
          orientation:'column', \
          alignChildren: ['left','center'], \
          filename: Panel { \
          alignChildren: ['left','top'], \
          filename_text: StaticText { alignment:'left', text: 'Filename ( Incremental numbers added automatically ): '}, \
          filename: EditText { alignment:'left', preferredSize: [430,20], text: '"+ docName +"', active: true }, \
          saveAs: Panel { \
          margins: 20, \
          spacing: 20, \
          saveAs_txt: StaticText { text: 'Save as: '}, \
          jpg: Checkbox { text: 'jpg', value: true }, \
          psd: Checkbox { text: 'psd', value: false }, \
          pdf: Checkbox { text: 'pdf', value: false }, \
          png: Checkbox { text: 'png', value: false }, \
          tiff: Checkbox { text: 'tiff', value: false } \
          btns: Panel { \
          margins: 20, \
          spacing: 20, \
          orientation: 'column', \
          alignment: ['right','top'], \
          save: Button { text: 'Save', properties:{ name: 'ok' }, preferredSize:[88, 24] }, \
          cancel: Button { text: 'Cancel', properties:{ name: 'cancel' }, preferredSize:[88, 24] }, \
          function makeFolder( path ) {
          var newFolder = Folder( path );
          if( !newFolder.exists ) newFolder.create();
          if ( app.documents.length > 0 ) {
          if ( app.activeDocument.activeLayer.layers ) {
          init();
          else {
          alert( "Error: \nSelect a parent group of the layers you want to export.")
          • 2. Re: Save all layer combinations of 2 folders and keep one layer outside of the folders always visible no matter what combination
            natrev Level 3
            Hi navamez,
            Can you give proper screenshot to proceed further?
            yajiv
