5 Replies Latest reply on Feb 7, 2017 9:29 AM by prhmusic2
    Manually Add Word docs as "linked documents"
    prhmusic2 Level 2
      On a network drive within the folder structure, there are 173 folders that have Word documents that I want to link from the network to my RoboHelp project. Is there a way to add these documents as linked documents all at once without navigating to each of the 173 folders?
        • 1. Re: Manually Add Word docs as "linked documents"
          Willam van Weelden Adobe Community Professional & MVP
          Are you up to some scripting? With a script, you can traverse all directories and link every word document that you find.
          If I had to make such a script, it would probably take me 2 hours. So unless you want to do this exercise more than once, you may be better of going through the folders manually.
          • 2. Re: Manually Add Word docs as "linked documents"
            prhmusic2 Level 2
            I was hoping to edit a config file like when I used to edit project files with Notepad in my WinHelp projects years ago. I think after I have the Word docs linked and after I have updated RoboHelp to create HTML files for each, I will look at what the .fpj files look like. Maybe I can manipulate them with some find / replace actions. And you’re right – this is a one-time task so looking @ the FPJ file will be a “when I have time” kind of fun project.
            Paul
            • 3. Re: Manually Add Word docs as "linked documents"
              Well, you can edit the rhWordDocs.apj file if you want to do it below the surface. It's just an XML and you can create links that way.
              • 4. Re: Manually Add Word docs as "linked documents"
                prhmusic2 Level 2
                William,
                I have to prep for a meeting in 20 minutes so I can’t roll up my sleeves and work on this at the moment, but you just made my day!!!!
                Paul
                • 5. Re: Manually Add Word docs as "linked documents"
                  prhmusic2 Level 2
                  The following is a snippet from my rhWordDocs.apj file. For each of the Word documents I'm linking to, the "template_name" value is blank. Where is that set within RoboHelp?
                  <word_doc>
                  <file_name>S:\Disaster Recovery Planning\_____DisasterRecoveryDocsSingleFolder\Refresh  MDR from REL and wipe.docx</file_name>
                  <settingsflag>0</settingsflag>
                  <afolder>Refresh  MDR from REL and wipe</afolder>
                  <pfolder></pfolder>
                  <type>2</type>
                  <location>2</location>
                  <flags>1073741824</flags>
                  <cshstring>TopicAlias</cshstring>
                  <authorstatus>0</authorstatus>
                  <status>3</status>
                  <template_name></template_name>
                  <cbt_mode>2</cbt_mode>
                  <buildtags></buildtags>
                  <toc_assoc>0</toc_assoc>
                  <index_assoc>0</index_assoc>
                  <glossary_assoc>0</glossary_assoc>
                  <override_flag>0</override_flag>
                  <gen_files>
                  <genfile>
                  <filename>Refresh  MDR from REL and wipe\Refresh__MDR_from_REL_and_wipe.css</filename>
                  <typeid>1</typeid>
                  <status>0</status>
                  <chksm>0</chksm>
                  </genfile>
                  <genfile>
                  <filename>Refresh  MDR from REL and wipe\Refresh__MDR_from_REL_and_wipe.htm</filename>
                  <typeid>0</typeid>
                  <status>0</status>
                  <chksm>0</chksm>
                  </genfile>
                  </gen_files>
                  <pattern>&lt;$paratext&gt;</pattern>
                  <asciionlyfilenames>0</asciionlyfilenames>
                  </word_doc>
