0 Replies Latest reply on Dec 2, 2008 10:22 AM by tharkad
    Setting chart axis min and max programmatically
    tharkad
      I'm just starting out with charting and I have a set of simple histograms to display. The charts must be created completely programmatically. I'm using this code to make the chart:
      chart = new ColumnChart();
      chart.dataProvider = histogram1;
      var columns:ColumnSeries = new ColumnSeries();
      chart.series.push(columns);
      This works great. In response to an event I change the chart to show a different historgram:
      chart.dataProvider = histogram2;
      The chart changes on screen. But the axes of the chart also change to best fit the data. For this application I would like to set the min and max of both axes so that the scale does not change when different data is displayed. I see MXML example of doing this but I cannot find a way to do it programmatically. In the debugger the chart variable has a horizontalAxis member with a maximum member but the code:
      chart.horizontalAxis.maximum = 40;
      gives poptiential access error and when running it does not change the maximum.
      Any ideas would be helpful.
      Thanks!
