3 Replies Latest reply on Nov 10, 2016 10:56 AM by Moshe.assulin
    symbols
    Moshe.assulin Level 1
      Hi
      I have a symbol that contains a picture, I duplicated the symbol several times. Now I want to replace the image with another, so that each symbol will contain a different picture, there is a way to get there?
      TIA
        • 1. Re: symbols
          joel_pau Level 5
          I assume you drag and drop your symbol from library to stage.
          You can use code or open your symbol and change your picture.
          Using code, there are 2 cases. Your picture is within a div tag or an img tag.
          So you open the creationComplete panel or the compositionReady panel.
          1) div tag:
          sym.getSymbol("symbolName").$("imageContainer")
          .css({"background-image": "url(images/imageName.jpg)", "background-repeat": "no-repeat", "background-size": "100% 100%" });
          2) img tag:
          sym.getSymbol("symbolName").$("imageContainer").attr("src", "images/imageName.jpg");
          You have to target each symbol. I assume you named your symbols: "picture1", "picture2"...
          It will be:
          sym.getSymbol("picture1").$("imageContainer")...
          sym.getSymbol("picture2").$("imageContainer")...
          • 2. Re: symbols
            joel_pau Level 5
            Here are demo files:
            div tag symbols.zip - Box
            img tag symbols.zip - Box
            About the css property (case #1). A shorthand can be used:
            .css( "background", "#ffffff url(images/imageName.jpg) no-repeat center / contain" );
            See: CSS background property
            • 3. Re: symbols
              Thank You.
