Hello,
We've been using an internal update server and a deployed mms.cfg to point internal client machines to a local web-server hosting Flash Player updates extracted from the background update .cab file, as detailed in the Administration Guide.
My FlashInstall.log shows the following:
<code>
2016-11-10+4-3-0.563 [info] 1631 /pub/flashplayer/update/current/sau/currentmajor.xml
2016-11-10+4-3-0.688 [info] 1630 /pub/flashplayer/update/current/sau/23/xml/version.xml
2016-11-10+4-3-0.688 [info] 1632
2016-11-10+4-3-0.688 [info] 1630 /pub/flashplayer/update/current/sau/23/xml/patch.xml
2016-11-10+4-3-0.704 [warning] 1445
2016-11-10+4-3-0.704 [error] 1301
2016-11-10+4-3-0.735 [info] 1612
2016-11-10+4-3-0.735 [info] 1620
</code>
My mms.cfg:
AutoUpdateDisable=0
SilentAutoUpdateEnable=1
SilentAutoUpdateServerDomain=myserver.domain
After a certain number of failed installations via Background Update Flash Player switches from Background Updates to Notification updates so that users will be prompted to update Flash Player and not miss the update. 1301 indicates that this threshold has been reached and the system is being switched to Notification Updates. We need to find out what's causing installation to fail and the switch to Notification Updates is occurring.
What operating system is this happening on?
Please upload the entire FlashInstall.log file from an impacted system to cloud.acrobat.com/send using the instructions at How to share a document and post the link to the uploaded file in your reply. If this is a 64-bit OS we need the FlashInstall.log file from C:\Windows\System32\Macromed\Flash and C:\Windows\SysWOW64\Macromed\Flash directories.
Thank you.
Maria
Please also provide the FlashInstall.log file saved at C:\Windows\System32\Macromed\Flash.
What version of Flash Player, if any, is currently installed on the system?
Post a screenshot of the contents of the C:\Windows\System32\Macromed\Flash AND the C:\Windows\SysWow64\Macromed\Flash
Thank you.
Maria
Hi Maria,
FlashInstall.log file are in the previous post.
I'm trying to install the version 23.0.0.207.
The FlashInstall.log file you provided is the one in the C:\Windows\SysWOW64\Macromed\Flash directory. I'm asking for the FlashInstall.log file in the C:\Windows\System32\Macromed\Flash directory.
Hi Maria,
There is new information on this error?
Sorry for not replying sooner.
The cause of the 1301 error is really the 1217 error:
2016-10-14+5-3-1.315 [error] 1217 -2146881269
2016-10-17+3-3-1.750 [error] 1217 -2146881269
2016-10-18+4-3-1.309 [error] 1217 -2146881269
2016-10-20+4-3-1.217 [error] 1217 -2146881269
2016-10-21+4-3-9.624 [error] 1217 -2146881269
2016-10-24+3-3-1.698 [error] 1217 -2146881269
2016-10-25+4-3-1.314 [error] 1217 -2146881269
2016-10-26+5-3-1.330 [error] 1301
1217 error = Failed to validate installer signature, or missing file or incorrect directory path
Since we've not received other reports on this (which would indicate a more wide-spread problem and lean towards a signature validation issue) it indicates an issue with the files deployed on your server. Please verify the files are deployed correctly and post a screenshot of the /pub/flashplayer/update/current/sau/23 directory, showing all sub-directories and all files, including the file/directory date/time stamp.
Thank you.
Maria
Hi Maria,
Thank you for posting the screenshot.
Please verify the md5 checksum on the files. They should be as follows:
File: fp_background_update\23\install\install_all_win_ax_sgn.z
Modified: Tuesday, October 25, 2016, 8:43:12 PM
MD5: D2314DA9AD8189BD0D4E57AE6EFBD7E8
File: fp_background_update\23\install\install_all_win_pep_sgn.z
Modified: Tuesday, October 25, 2016, 8:43:22 PM
MD5: 24375B65ECBDF521D72E8BF5184587C4
File: fp_background_update\23\install\install_all_win_pl_sgn.z
Modified: Tuesday, October 25, 2016, 8:43:18 PM
MD5: 985246A07F7083525776CE116DA0ECCC
Thank you.
Maria
Hi Maria,
Thank you for posting the information. A few more questions:
Maria
