4 Replies Latest reply on Nov 10, 2016 11:13 AM by finnandme
    Quick Reset Required!
    finnandme Level 1
      While I'm learning Ch, I'm constantly making a adjustments to what effect it has, but the problem with this is, I soon forget where I was in the first place?
      1. The Undo cmd+Z and Redo shift+cmd+Z is very useful, but sometimes I would just like to be able to Reset and start again! Is there a Reset option?
      2. I would like to turn off the options/settings, so I can see, from scratch, what each does in turn. Is there a Blank Canvas of Settings? Hope that makes sense!?
        • 1. Re: Quick Reset Required!
          finnandme Level 1
          I notice that when I click on the Scene... I can make adjustments and I get a X... If I click on this, it resets to default setting. Great!
          However, when I click Puppet, I seem to get the same settings, but when I make adjustments.. no X? You have to double click and then enter 0, press Return/Enter to reset?
          • 2. Re: Quick Reset Required!
            oksamurai Employee Moderator
            1. Best option for a reset is in the history window. Window > History. Just highlight the first thing in the list and you'll rewind to the start.
            2. In the puppet panel some properties (track item behaviors) have a little menu icon next to them - you can remove or hide them in the scene from there.
            3. The puppet values are a foundation, the defaults for your puppet. Yes, there is no X - you determine the defaults for what works best with your art. Once you're in a scene, that X means "restore to default" - whatever you've set originally in the puppet panel.
            • 3. Re: Quick Reset Required!
              finnandme Level 1
              Hi Again!
              The History Panel.... In Ps I paint and use History a lot.. never gave this a though in Ch... amazing!
              I've just checked this out... Selected it from Windows.... Wow.. it goes way back to when I first started using and not just the latest session! I've pulled the History Panel away from the Main WorkSpace and have it as a floating Window.. this will be very useful!
              I'm still not 100% sure why there are two Properties.. Panels that seem to be showing the same thing, although one is slightly different. However, it may become a bit clearer when I get further into Ch!? I'm still working on a head and one eye! Slow... I know!
              Thanks again for your invaluable help!
              • 4. Re: Quick Reset Required!
                finnandme Level 1
                Just realized  the Floating History Panel remains a part of the WorkSpace I created... So it pops back up as soon as I open Cn... Excellent!
